Old 04-09-2018, 02:40 PM   #1
ColdfuzionTN
Drives: 2012 Camaro SS
Coolant Temp question
Just a curious question but what coolant temps are you all seeing using a 160 thermostat? Mine has been running around 194 with all this cool weather. Just figure it should be lower but not sure. Don't want to run into any issues when it warms up.
Thanks for the info ahead of time.
ColdfuzionTN is offline   Reply With Quote
Old 04-09-2018, 03:03 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
160 degree means it opens at 160°, not that temps will be 160°. I see 204° At stop lights but 174° when temps are in the 50’s and I’m driving on the highway. Once the car is warmed up, the temp is the temp while sitting. Only driving on the highway will you really see some temp difference — if It’s hot outside (90° and above), it will have very little difference than a 180° t-stat..
-Don
747 RWHP 794 RWTQ
Old 04-09-2018, 03:39 PM   #3
ColdfuzionTN
Thanks I was just curious as it was 55 out this morning and I have a two hour commute and was going around 194 but it stayed constant. Thanks for the info
Old 04-09-2018, 03:53 PM   #4
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Did you get the car tuned, and have the fan points changed? If you just swap the thermostat, but don't change any of the fan settings, you'll keep higher temps like normal unless you are on the highway on a colder day getting nice cold ambient air.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 05-14-2018, 10:22 AM   #5
WoodBoss
"Old School"
Drives: 2010 2SS L99
Mine runs between 180 and 185 when it's hot out. My fans come on way before that temp. When it's cold out below 40 degrees F, it runs about 165-170. If you are running above that with a 160 thermostat either your fans are coming on late or you may still have air in the system.
WoodBoss is offline   Reply With Quote
Old 05-16-2018, 11:22 PM   #6
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
the highest mine has ever gotten is 199 and that was in L.A. traffic with the AC on
other than that it usually hangs out around 185
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-18-2018, 08:19 PM   #7
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Mine stays around 192 year round unless I'm in traffic.
I still have the Stock thermostat
StingrayblueSS is offline   Reply With Quote
Old 05-19-2018, 11:37 AM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Let's keep in mind that all these systems are pressurized, and temps over 212 degrees are not out of the norm, and are certainly not unsafe. I live in the desert, and even with a good aftermarket radiator, I still can see temps over that in extreme summer temps here while driving aggressively. Doesn't worry me. For those of you who live in more temperate areas, I guess something over 212 may seem high. It's not......
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-19-2018, 05:46 PM   #9
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
184-192 cruising, 192-194 in slow traffic, have seen 204 at long stops in hot weather, but comes down quick once moving. My fans have been tuned to come on around 187.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 05-21-2018, 01:22 PM   #10
joelg1988
joelg1988's Avatar
Drives: 2011 2SS RS -LS3- 6MT - Victory Red
I live in the desert too, and for me these are the normal temperatures I see everyday (I'm still running the stock thermostat):
*188 to 192 cruising on the highway.
*210 to 224 idling in traffic at 85+ degrees.
*196 to 201 driving on the hwy with A/C on and 105+ degrees out.
When I see 224 idling in summer traffic i get a little nervous but I've seen other threads that LS engines tend to run hot.
In comparison, I have a 2017 Toyota Yaris and it has never gone over 198 degrees. I also have a 2009 Cobalt that I Uber the shit out of it and never sees over 210 degrees.
2011 2SS RS - LS3 - 6MT - Victory Red | Las Vegas, NV
joelg1988 is offline   Reply With Quote
Old 05-21-2018, 06:32 PM   #11
StingrayblueSS
What temps do you think are the best at the drag strip.
Can you tell the difference between 160 and 190
Old 05-22-2018, 08:02 AM   #12
WoodBoss
"Old School"
A 160* thermostat is perfect for the dragstrip. The car runs better/faster at 170 or 180. Sitting in staging lanes, trying to keep the car cool or off as much as possible in the hot weather I saw 210*-225* quite a bit. The stock thermostat is a 187. I tried a 180, 174 and the 160 before I was satisfied. Changed out the thermostat, had my tune altered to have the fans come on earlier and now even on a hot day in the sun my car does not go over 185*. When you change your thermostat be sure to get all the air out of the system otherwise is will run hotter than it should with the new thermostat. I wasn't able to get all the air out until I pulled the top radiator hose and filled from there, it made a huge difference. Good luck and check out my Youtube channel for the video on how to change your thermostat. I really need to do a part 2 on that thermostat video to add to some of the stuff I learned over the couse of swapping and purging the system.
Old 05-22-2018, 03:48 PM   #13
StingrayblueSS
Thanks, I may go to a 160 thermostat someday.
Old 05-23-2018, 10:54 AM   #14
sixty9fordkiller
Remember to get the car tuned if you do. No point if going with a 160 thermostat if not tuned for it. The upstream O2 sensors (for examaple) will likely complain about not getting hot enough quick enough and a CEL will be the likely outcome.
Timing and air/fuel ratio may be affected as well
Bone Stock
