Old 04-10-2018, 08:48 PM   #1
ecreps
Drives: 2014 1LE, 1996 z28
Bosch 210lb/hr injectors
Just wondering if any of you have any experience with these. Mostly wondering if they will idle ok on pump gas. Planning to run E85 the majority of the time, but would like the ability to run Straight 93 as well.
http://www.vsracing.net/catalog/prod...oducts_id=1397
ecreps is offline   Reply With Quote
Old 04-11-2018, 09:02 AM   #2
CGbambam
Drives: 2011 Camaro 2SS
They run fine, been running them over a year no problem. They just don't come with injector data which some tuners hate, and you need a little adapter pigtail since they aren't ev6. I even flowtested them prior to installation and they all checked out fine
CGbambam is offline   Reply With Quote
Old 04-11-2018, 09:31 AM   #3
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Im also running them. Idles fine and runs fine. Setting on 22lbs of boost and 53% duty cycle.
For $350 You can't beat them. Casper Electronics makes the adapter for the Denso to Ev6.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 04-11-2018, 08:04 PM   #4
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
same, I'm using them but have yet to start it.
ttshovel is offline   Reply With Quote
Old 04-12-2018, 06:10 PM   #5
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
The sloppy mechanics guys use those made 1000+ on e85
That's what I'll use if/when I max out my 1000s
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-12-2018, 07:05 PM   #6
ecreps
I just wondered if idle on pump gas would be under the minimum pulsewidth. Import guys seem to have some issues with it, but they are generally only around 500cc/cyl.
These injectors with a pwm walbro 450 seem like a good budget fuel setup.
Old 04-12-2018, 09:27 PM   #7
fif_gen_powa
what is this pump gas you speak of, never heard of it
8.3@164
