Old 04-11-2018, 07:20 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
E85 question
Any reason why the flex fuel sensor would read less Ethanol content at redline (71%) than at Cruising speeds (78%)?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 04-11-2018, 11:56 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Where did you tap into power to feed the sensor?
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 04-12-2018, 08:22 AM   #3
Jkelley3209
Jkelley3209's Avatar
Drives: Savage ls
E85 question
Delete
Jkelley3209 is offline   Reply With Quote
Old 04-12-2018, 08:32 AM   #4
2010_camaro
Runs on its own relay.
Old 04-12-2018, 04:53 PM   #5
trw427ss
trw427ss's Avatar
Drives: 2013 2SS/RS L99
If you have the flex fuel sensor on the return side of the fuel system it will do that because there is not a constant flow of fuel through the sensor at peak fuel demand.
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss is offline   Reply With Quote
Old 04-12-2018, 08:35 PM   #6
schpenxel
Drives: 2005 Corvette
Yeah, need fuel flowing through the sensor all the time or you'll get weird readings..
2005 Z51 Corvette, M6
ECS 1500 Supercharger
Monster LT1-S Twin, AlkyControl Meth, ID1000's
220/240 118+3 Pat G Cam
BTR Platinum Springs / Trunnion Upgrade, Z06 Manifolds/Exhaust
Build Thread
schpenxel is offline   Reply With Quote
