Old 04-12-2018, 10:29 AM   #1
1970judge
Drives: 2015 Z/28, 2007 HHR
Auto x oil
For those that are auto crossing, are you running the specified 15w50 track oil, or sticking to the 5w30. Short runs, I would imagine it would be fine to run 5w30.
Thinking of participating in auto-x a bit this year. This could mean more seat time for less $, in between track days..or more $ long term if I am changing oil for auto-x events like you would for track days.
Advice is appreciated.
1970judge is offline   Reply With Quote
Old 04-12-2018, 01:51 PM   #2
mybadZ28
Drives: 2015 Camaro Z28
I run 15/50 and PF64 for track and autocross
mybadZ28 is offline   Reply With Quote
Old 04-12-2018, 09:59 PM   #3
serviceguy
Drives: 2014 Z/28 # 89, 69 Camaro, 2013 ZL1
Where do you Auto X cross at ?
I run Mobil 1 15/50 for track days.
serviceguy is offline   Reply With Quote
Old 04-13-2018, 06:52 AM   #4
1970judge
I haven't done it yet. There is Detroit SCCA and Saginaw Valley SCCA.
Detroit runs in Livonia and at MIS usually.
Saginaw runs at Midland/Barstow airport, Nexteer in Saginaw, and in Oskoda at the airport.
Old 04-13-2018, 07:08 AM   #5
mybadZ28
Auto X
http://drscca.org/ go here this is the detroit region SCCA site they have the schedule posted under the solo tab they go to Oscoda several times they also have a pro-solo there also I did that last year lot of fun, went to Oscoda 3 0r 4 times last year, pretty big course.
Old 04-13-2018, 08:30 AM   #6
1970judge
I believe the 28th for DRSCCA at MIS will utilize the road course too, which would definitely help my vision instead of a huge parking lot.
Old 04-13-2018, 09:10 AM   #7
ZapperZ
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
Joe Gibbs LS30 motor oil
ZapperZ is offline   Reply With Quote
Old 04-13-2018, 09:26 AM   #8
tylerio
EXTREMZ
tylerio's Avatar
Drives: 2015 Z/28 #891, 2012 2SS 45th Anni
I run 0/40 PF64 for auto-x and track.
ARH long tube headers, no cats
Comp Cams stage 2 custom grind
Ported throttle body
JPSS Oil cooler
JPSS SAI plates
JPSS Rear sway bar
Forza Continenti exhaust controller
ZL1 Add-ons wickerbill
Brey-Krause Harness bar
Schroth 4 pt. ASM harnesses
Auto-blip
tylerio is offline   Reply With Quote
Old 04-13-2018, 09:09 PM   #9
1970judge
Thanks for the feedback!
auto x, auto-x, autocross, autocrossing, oil
