Old 04-12-2018, 08:45 PM   #1
str8wick3d
Drives: 2011 Camaro SS
Tick Polluter Installed. Dyno Video and Sheet Inside
464/441 BBK longtubes straight pipe no x or h to pype bomb axle back, k&n CAI, stock gears M6
https://nemesis-racing.com/media/featured6.mp4
str8wick3d is offline   Reply With Quote
Old 04-12-2018, 10:04 PM   #2
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
You're losing power not having a X or H-pipe.
0331Marine is offline   Reply With Quote
Old 04-12-2018, 10:13 PM   #3
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Agreed..........
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 04-13-2018, 04:34 AM   #4
str8wick3d
I agree to. Car came with the exhaust setup haven't changed it.
Old 04-13-2018, 08:08 AM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
good numbers! i wonder how much an h or x pipe would change them
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 04-13-2018, 08:30 AM   #6
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
What wheel set up are you running? thing looks MEAN
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 04-13-2018, 01:28 PM   #7
str8wick3d
Racestars 18rear 17front gives it a mean stance but it doesn't get along with abs lol
Old 04-13-2018, 02:00 PM   #8
0331Marine
0331Marine's Avatar
Tire sizes are wrong then. There's too much of a difference between the front and rear.
Go on YouTube and watch Engine Master's Ep22
Old 04-14-2018, 06:00 PM   #9
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Nice Camaro!! What tire sizes?
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-15-2018, 07:56 AM   #10
Bo White
Bo White's Avatar
Thats about what it would make on my local dyno. good power
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 04-15-2018, 12:55 PM   #11
christianchevell
old school chevy rodder
christianchevell's Avatar
Even with using STD standard for a correction factor which does show higher than SAE ratings the tuner used smoothing also on your dyno sheet not showing much for them IMO
As others said a cross over to make the exhaust pulses even out helps, Given the long duration and lift I would expect more power for that cam with a tune from my tuner even on a Mustang with SAE printout ; even with power steering pump the 11 has etc.... I don't exactly know the specs of the exact cam you have but usually a good polluter is more in the 480 range with a TSP 235/239 or the night fury grind right behind it. But as known dynos are just tuning tools, so good for you getting it installed I would myself though look to upgrade the intake some just for the $$$ though its hard to beat some cheaper parts like K&N.
And total builds do rack up the bucks your smart to have done trunnions. Just like a dogbone dampener, or high volume pump it can save money down the road. I am old school and insist on a break in with Driven racing br30 break in oil. And different gears or tire diameters etc...... can make a big difference on power level shown if not calibrated correctly to the dyno and tuning software. Anyway thats IMO being here for so long. Any dyno is only as good as those operating it as with tuning usually. Not pulling timing and evening out AFR and setting it for WOT and etc etc all matters. But what really matters is the Perma Grin and the feel in the seat of the pants..... ET phone home....LOL
Old 04-19-2018, 09:57 AM   #12
str8wick3d
17 in front 4.5/28 18 in rear, 305/45/18r Thanks!
Old 04-19-2018, 09:58 AM   #13
str8wick3d
Thank you sir!
Old 04-24-2018, 04:20 PM   #14
NikolaiD
Drives: 2002 M3, LS3, TR6060
Nice, I was just looking at possibly getting this cam.
I have the stage 1 tick cam and it made 440/420, I was wondering how much of a bump I would get from this.
Thanks for the video, it helps a lot.
It's a little too choppy for my liking, I think I'll stick with what I have for now and look for other options.
NikolaiD is offline   Reply With Quote
