![]() Drives: 1111 Join Date: Sep 2009
Storing your Camaro
Well I did a search on camaro5 and found some info on storing but its spread out on numerous threads. So I thought this might help some people like me.
![]() I did find a couple of articles on storing your car. http://www.techguys.ca/howto/winter.html http://news.carjunky.com/automotive/...e-cde951.shtml Im not changing all my fluids except for the oil, and Carjunky says "Some will say to put the car on blocks, but with modern independent suspension, it's not good to leave it 'unsprung' for long periods". Just wondering what do you guys think? |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: CHEVROLET Join Date: Jul 2008
Now my question is, and I'm looking for feedback: When is the best time to change the oil, before or after storage? (would clean oil sitting over winter not breakdown, as much as used oil?), this is the only part that I still can't get a clear answer on. I was thinking of holding off until spring, than get a nice drain of the old oil and have clean fresh oil to start, and get me through the new season. PLEASE HELP!
#3 | |
Im going to do the same thing, I figure how much more can my old oil breakdown in 4 months? only got 3k on old oil. |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
I have 2200ks and stored it already with the factory oil. If its mobil1, why would I put new oil in it just so it can collect moisture and dump it in the spring? Its good for awhile still and it can collect moisture all it wants till spring. I've never put new oil in any of my camaros when i stored them. Never had a problem as long as I changed it as soon as it came out of storage. As a tech i've seen people needlessly spending money on their oil. I've almost collected some peoples oil to put in my beater cause of how clean it still is.
So i'm changing it in the spring and will not lose sleep over it. I will start it up bi-weekly as well to keep the coolant from settling to the bottom of the rad, heater core and block. People talk about moisture in the engine... B/S, the internals of an engine don't go dry in a span of 5-6 months. the oil keeps everything slick. As long as you get to operating temps, you're ok. I've rebuilt many engines and a little moisture never hurts them. I never find evidence to point to improper storing. Save your money on the oil change. Spend it in the spring. Do you think us at the dealer worry about the cars sitting the winter out without a buyer worry about changing its oil? Nothing bad will happen. |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
2200km time to cahnge the oil anyways!
#6 |
Psycho on day pass
And when it comes out of storage, it will still have 2200ks and then will change it.
This topic is like asking whats the best way to raise a child? |
#7 |
Change the oil before you put it away. The contaminants in the oil can eat away at bearing and crank surfaces. If you left it till spring to change, it will have all settled and attached and be more dificult to have a clean environment.
Do you brush your teeth before you go to bed?
SPi Performance Stage 3 package Comp Cam
PHADT FE4 ZL Stg.3 VMAX CNC Spiral Ported Throttle Body Dynatech LT headers, Hi flow Cats MBRP 3" 304 stainless X-pipe exhaust Fastlane true CAI. Barton shifter |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 1LT|RS|SIM|M6|BA Stereo Join Date: Jul 2009
i asked the oil change question in the cosmetic part of the forum and the guys there said do the oil change after hibernation...
1LT | RS | M6 | SIM | BA Stereo 1000 - [07-23-2009] Order Made at dealer 1100 - [08-04-2009] Preliminary order accepted 2000 - [08-25-2009] Accepted by GM 3000 - [09-01-2009] Accepted by production control TPW = 10-05-2009 3300 - [09-28-2009] Scheduled for production 3400 - [10-01-2009] Broadcast - Being Built 3800 - [10-13-2009] Produced - Built- VIN 2G1xxx54917 4200 - [10-19-2009] Shipped 5000 - [10-19-2009] Delivered to the dealer 6000 - [10-20-2009] Delivered to the customer |
#9 | ||||
My mechanic agrees with this too.Quote:
#10 |
In The Circle
Thanks for the back up. Storing it with fresh clean oil is better for it, then contaminated oil. Since it's due, might as well.
#11 |
![]() Drives: 2010 SS RS IOM M6 Join Date: May 2009
My two cents about changing your oil before storage or not,
Oils are designed to suspend acids and other byproducts of combustion so they don't come into contact with the engine and cause damage. If you change your oil at or before recommended intervals and you are not approaching said interval then i don't think you'll do any harm by waiting until spring to change your oil. That being said however if you frequently start the engine during the winter you will degrade the oil much faster than if you hadn't started it (another debate i know), In this case then i would want to have fresh oil (or not very old) in before storage. Remember here that it's water dissolving some of the combustion bi-products that produce acids and starting the engine will contribute to more condensation. If on the other hand you are not as diligent about changing the oil when you should then i would definitely recommend changing it before storage. Another thing to keep in mind is if you do want to leave your car with fresh oil over the winter consider using regular oil instead of synthetic. It's a misconception that synthetic and regular oils don't mix so to save the cost of a $100 plus oil change use regular oil for storage and switch back to synthetic when you bring it back out. I don't think there is a definitive answer here but for myself with less than 2000k on my oil i won't change it until spring. I also won't be running the engine either. Ken
Delivered July 30 2009
#12 |
Born: August 27, 2009
Drives: 10CAMARO SS,12CRUZE RS,07 YAM R6 Join Date: Aug 2009
Like Canadian SS said, he is going to start it and run it up to temp, every other week. Thats what I plan on doing aswell. So how will he contaminents have a chance to ruin any internal parts. I am with him, fresh oil upon wake up for a long summer.
Victory Red 2SS/RS
Vin# A9130145 |
#13 |
thanx to everyone, for the input, on the oil change topic.
#14 | |
No issues with my Firehawk over the seven years of storage. Just my 2 cents. Kelly
2010 Camaro 2SS, IOM, IO Interior, RS, 6M
Came home 09-07-22 VIN# 25963 1969 Firebird 400 1978 Camaro 305 V8 1994 Firebird Formula LT1 2002 Formula Firehawk LS1 |
| Songs About Camaros (for your driving pleasure) | Emjay | 5th Gen Camaro SS LS LT General Discussions | 74 | 12-18-2014 01:42 AM |
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 01:25 PM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 08:33 PM |
| Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 06:33 PM |
