04-13-2018, 08:43 PM | #1 |
My camaro driver seat is jammed!
Hello everyone, my seat is stuck. I moved my seat back to chill like a villain. When I tried moving it back in to the position I had it. It wasn't working. The only thing it does is move back. Now it's stuck all the way back. What to do. Any advise? Help!!!!
04-13-2018, 08:52 PM | #2 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
wow, crazy. How far to a local repair shop? Open on Saturday? Go really early in the morning if not too far to avoid traffic, sit in the parking lot till they open...
lol, I've got nothing... good luck man. Maybe disconnect the battery, or check the wiring underneath. |
04-13-2018, 09:18 PM | #3 |
I disconnect the wiring underneath the seat, no luck. Quick question though. If I disconnect my car battery while it reset the computer? I need to check the fuses that's underneath the seat as well. Repair shop is like 1 minute away.
04-13-2018, 09:18 PM | #4 |
*will
04-13-2018, 09:22 PM | #5 |
Disconnecting the battery shouldn't mess with your computer. But some things do reset. Worth a shot. That repair shop may be your best bet though if everything looks normal. Could have a busted the motor or something touched and shorted when you moved the seat back.
04-14-2018, 04:52 PM | #6 |
This is why I prefer to chill like an old lady. Less stressing about GM's failures.
Besides, my seat already adjusts a bit wonky. Its not a steady adjustment, like you can feel the motor is struggling. The struggle is real.
04-14-2018, 05:49 PM | #7 |
Maybe try tapping on the motors while holding the switch in the forward position?
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
04-14-2018, 06:11 PM | #8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
There’s an old Mc D’s bag and half eaten cheeseburger wrapped around the lead screw!
04-15-2018, 12:55 AM | #9 |
Drives: 2011 LT Black Join Date: Nov 2011
There is a recall for the Seat Height adjuster. If that wasn't fixed possibly the nut or bolt is jamming it if it broke off.
04-15-2018, 07:33 AM | #10 |
I checked the fuses and the problem isn't there. I checked all the motors that controls the seat postion. They all seem to be working except the reclining that's located behind the seat. It moves all the way back but foward, nope. I checked if the wire had current and it does. Do you guys think the problem is the switch or the motor that needs to be replaced. Any advise on how to remove the plastic part besides the seat to check the switch box.
04-15-2018, 08:33 AM | #11 |
Drives: 2010 2LT/RS Join Date: Mar 2015
I had that problem one time on the passenger side. Found a pen lodged in the middle of the track/rail which prevented the seat from moving. Got a screw driver and pushed it out. Problem solved.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
04-15-2018, 08:59 AM | #12 |
Still no luck in my side. Need help.
04-15-2018, 01:54 PM | #13 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
If you are certain nothing is jammed my guess would be switch.
You might be able to depin the connector at the motor and reverse them temporarily. I'm betting then when you push the seat back switch it will move forward. Don't move it too far forward then unplug it and it's now non moveable until you fix the switch later. BTW I don't know anything about camaro motor wireing and e.g. if it's grounded somehow an it won't blow a fuse or burn down your car. Proceed at your own risk and or use a multimeter and wiring schematic to figure it out. |
04-15-2018, 02:09 PM | #14 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Did you look underneath to see while you were chillin like a villain you didn't drop your beer bottle and jammed the seat?
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
