Old 04-15-2018, 06:54 PM   #1
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Help with Procharger accessories
So I finally got enough to get the tuner version of the stage 2 D1x procharger.
I already have a sniper efi fabricated intake manifold as well as a fuel rails for it and NW 102mm TB to fit the intake. Now for me it is still a daily driver and I would want to take it to the track once in a while. So the question is as follow. Does anyone have that setup and if so what fuel injectors are you using and what clutch are you guys using.
In regards to a clutch I was actually thinking of getting a monster clutch twin disk clutch rated for either 750hp or 1,000hp
In regards to the fuel system I was looking at the fast 65lbs injectors. I am going to see if I get a tune as conservative as possible. Any advice would be appreciated it.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 04-15-2018, 07:37 PM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
A set of id850 and id1050x injectors in the for sale section right now
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 04-15-2018, 09:54 PM   #3
Rcheli4fun
Drives: 2011 camaro 2SS RS
DYAD Center force clutch feels vary close to stock some others have a vary hard clutch peddle also ID850s
Rcheli4fun is offline   Reply With Quote
Old 04-16-2018, 08:20 AM   #4
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Don't spend the money more than once when it comes to fuel system. Buy a squash, fore, or AGP kit. I would also go with a minimum of 1300 injectors. Give yourself the room to grow because you WILL want to grow. I have a very similar setup to yours except the shortblock was a ERL 427 and a F1A procharger. I would look into flex fuel as well if E-85 is available in your area. I am using ID1700s with a squash dual pump kit and a McLeod twin clutch rated for 1000hp. Also will want to look into a driveshaft and axles. Mine is currently handling 720RWHP with ease, turning it up this week to make closer to the 850-900Rrwhp range. Always plan for more.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 04-16-2018, 11:07 AM   #5
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
New Setup here Running D1X Stage2 with Race BOV and Intercooler on 13 lbs and 100% Meth Injection. (may go to E85 evetually but quality and availability around my neighborhood is poor still ) Currently running Vengeance Racing 1000 Injectors for now with a Monster Triple LT1-S. Went with the S instead of the SC. S imho just a lot better for Street. Love the Clutch so far. Very little to No noise like some of early units and it will handle a lot more than the rated 1000. Car is setup and geared for 1/2 mile Racing and Street use. Imho the D1X Unit and the Clutch is fantastic on the Street.Will be testing out the new power for first time in the 1/2 next month in GA and chomping at the bit. Had to miss a great 1/2 mile this weekend in Dallas for work. Dang work Best wishes.
Bildo just noticed your sig We think alike lmao
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 04-16-2018, 12:34 PM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
You have a supercharger capable of 1000 HP so you should match your fuel system and injectors to support that blower.
On Gasoline you will need a Fore or Squash return style fuel system, and min ID1050X injectors.
If you have Ethanol fuels available to you take advantage and get some ID1300X injectors.
Be happy to help you with your project.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-18-2018, 01:33 AM   #7
rgrmoreira13
so for now after doing research and asking ppl all over. I ended up getting a monster LT1 twin disk clutch and ID1050x injectors. I also am getting a meth kit. I am trying to see if I go as conservative of a tune as I can as this is my daily driver and will need to make sure it is able to handle in the street.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
