![]() Drives: 2010 Chevy Camaro Join Date: Apr 2018
My driver window was having some issues with indexing and the button down hold then button up hold wasn't fixing the issue but for a couple hours. So, we unplugged the connector to the driver door, left it off for a minute, and then plugged it back in. Now the driver window won't work at all (up or down) and when I turn the car off and open the driver door there is no "ding", the radio stays on, interior lights stay on, and I can continue to roll the passenger window up and down from the driver door.
What is wrong? Did we mess something up by pulling out that connector? I should probably say before we unplugged that connector everything was at least working normally except for the window indexing. I'm so frustrated because every time I get out of the car now I have to disconnect the battery so it doesn't drain from the radio and lights being on! PLEASE HELP! |
![]() Drives: 2013 Camaro ZL1 Convertible Join Date: Dec 2013
Try disconnecting battery.
When I replaced my battery ,same thing happened |
Sorry, just read last line where you already tried
Yeah, I tried disconnecting negative and positive and it didn't work. When I get out of the car now I just disconnect then re-connect the negative. It at least turns everything off so the battery doesn't drain.
Drives: Fast Join Date: Mar 2015
How did you end up in the ZL1 section for this question? You'll get MUCH more traffic in a proper SS or general Camaro 5 section.
#6 |
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
http://www.camaro5.com/forums/showthread.php?t=70683 |
#8 | |
Sorry.
#9 | |
#10 | |
Try this.. |
#11 | |
#12 |
![]() Drives: Chevy Camaro & Chevy Silverado Join Date: Mar 2019
Hey Camarofrustration did you ever find the solution to this issue. I’m having the same problem myself.
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
#14 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
Last Activity: 04-17-2018 01:07 PM
Levon H. Bone Stock |
| Tags |
| driver door, driver window, radio on, window drop, window issues |
