Old 04-17-2018, 08:11 PM   #1
Arends-1le
Drives: 2015 Camaro 2SS/RS 1LE
Pushrod length?
Need pushrod length help for my ls3 camaro. Have btr stage 4 cam, ported my heads, and morel 5290 lifters. I think the morel lifters want .03-.05 preload, any clarification?. When using the 6.8-7.8 pushrod checker took from comp cams, I'm getting 9 and there quarter turns for zero lash. Which is 7.2875. After adding .05 preload i get pushrod length of 7.3375. When I use my 7.4 pushrods, i get about 1.5 turns to bottom out the rocker bolt, which is too much. Do I want 7.35? That would give me just over .06 of preload. Just wondering if that will work smoothly with these lifters.
Arends-1le is offline   Reply With Quote
Old 04-17-2018, 08:26 PM   #2
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
if the range is .03 to .05 then use a 7.325 pushrod for 0.0375 preload or custom order a pushrod set at the desired lenght. Do the lifers come with the preload spec? you sounded uncertain about it.
zz430camaro is offline   Reply With Quote
Old 04-17-2018, 08:32 PM   #3
Arends-1le
Double checked the paper, .045-.05 from morel. I pulled .03-.05 from web
Old 04-17-2018, 10:37 PM   #4
zz430camaro
Drives: 2015 1LE
If it were me I would measure that on a few cylinders then order the proper length
Old 04-17-2018, 10:57 PM   #5
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
x2 for the checking a few. That's a really tight preload range to try and hit
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 04-22-2018, 11:46 AM   #6
Russell James
Russell James's Avatar
Like mentioned, measure a few cyls both int and ex. Then come up with a length that puts the preload between .04 and .05. Then call a PR company like Trend and see if they can do a custom length. If they'll make any length, I'd shoot for that .05. If your PTV is real close, shoot for the lower end of the range .04. Plenty of PTV, go .05.
Old 04-23-2018, 06:48 AM   #7
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Yes, different lifters,heads,block combo.Definetly double check to get the right preload. Mine is 7.575 push rods with 0.035 preload just to compare with Johnson short travel lifters.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
btr, comp cams, morel, preload, pushrod
