Old 04-18-2018, 08:47 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
What is the normal IAT range for a SC ls3 on 93
Im running 93 octane, 10 pounds of boost and im seeing a max iat of 111 degrees F. My buddy runs 10 psi on a P1sc on E85, and his iats peak at 140.
He has the stage 2 intercooler from procharger. I have the standard ESS, which is a beast.
Obviosly lower is better, but are these temps normal?
Its about 85 degrees here in Florida.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-18-2018, 09:46 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Not a supercharger, but with twin turbos I am usually 20-25* over ambient. I have the AGP giant intercooler.
That is just driving around. I don't know what it is when ran hard because I have meth injection and my IAT sensor has been moved to the intake which is a Holley Hi Ram that retains heat because it is metal and not plastic.
What you reported seems pretty normal. The IAT will always be over ambient unless you are using meth, nitrous, etc especially under boost. Every setup is going to be a little different.
Old 04-19-2018, 08:08 AM   #3
eLeSthree
Cruising i see 10-15 over ambient. I just found it strange that his are so much higher and he runs e85. But i guess that has nothing to do with it. He thinks his car is down on power and these high iats are all i could find abnormal in his logs.
1158whp 1017wtq.
630whp 658wtq
Old 04-19-2018, 01:03 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The E85 doesn't do anything until it is in the cylinder. The IATs are being measured before the air and fuel get mixed.
I have heard the procharger intercoolers aren't that great but I have no direct experience with them.
Old 04-19-2018, 01:29 PM   #5
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
I am usually very close 1-2* above ambient temp cruising. This is florida heat always 80+ outside
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-19-2018, 01:39 PM   #6
hillshooter
Drives: 2015 Camaro SS commemorative
10-20 over Ambient.
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 04-22-2018, 12:56 PM   #7
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Live in FL. Have the Race Intercooler with StageII D1X and have not seen anything close to 140. Usually Ambient or + a few like others here stated.( Not spraying any Meth until app 4lbs.)
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 04-22-2018, 02:25 PM   #8
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I'm also seeing 10-20 degrees over ambient. The IAT will depend on whatever your outside temps are. I'm running an LSA with a stock IC and a 2.75 upper pully. I am worried about the IAT's when it starts getting into the 100's here in AZ......
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-22-2018, 02:57 PM   #9
hammdo
'It's an experiment'
hammdo's Avatar
22° to 26° over ambient @ cruise but, I have a 2.45 upper and 18% lower ported snout and blower running E85. I have an intercooler and 3 HXs. IATs no issue as I also have extra coolant for the SC. E85 cools the cylinders so, we pull timing at a higher IAT because of that. Road race it as I’m always watching the temps and KR...
-Don
747 RWHP 794 RWTQ
Old 04-23-2018, 11:09 AM   #10
eLeSthree
Not sure how fast your spinning the D1X, but im sure its more efficient than the P1sc. Are you saying during a 3rd gear pull at wot you’re seeing just a few degree over ambient?
And if your meth kicks in at 4 psi, thats hardly a fair comparison lol.
1158whp 1017wtq.
630whp 658wtq
Old 04-23-2018, 08:46 PM   #11
SSBUSDRVR
SSBUSDRVR's Avatar
13 lbs on Street. Lol yeah maybe not fair comparison. It hasn’t seen the Heat of our Summer yet but it’s been pretty warm already here the last month. On the Street has rarely gotten above 4psi .( AlkyControl System) Have an IAT Alarm on the DashControl HUD Unit set at 160. Will be running it’s first 1/2 Mile of year In 3 Weeks. Will see what kind of IATs it sees in WOT Conditions. Best Wishes. 🙂
Old 04-23-2018, 09:07 PM   #12
CrazyRED
CrazyRED's Avatar
Drives: 2014 2SS RS 1LE
I've just recently jumped into the world of FI so please forgive my uneducated question.
Are you guys tracking IAT's real time or are you just checking logs? I'm having a real problem with power loss here in Florida as well.
CrazyRED is offline   Reply With Quote
Old 04-23-2018, 09:44 PM   #13
DSMer1
Drives: 14 and 15 SS's
My last Dyno was with the Whipple blower, and Whipple HX, not using my interchiller.
After 4 700+rwhp pulls iat's were peaking around 120 I think.
This was in a Dyno room and the room temp was about 70 degrees but there wasn't much air moving. Not having air moving is a killer, my iat's are 100+ sitting at idle with 40 degree water temp.
eLesThree, your iat's seem good. What blower and where is your intake filter?
It seems like your HX of doing a good job.
You friends don't seem that out of whack though.
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 04-23-2018, 09:53 PM   #14
hammdo
hammdo's Avatar
I road race mine. 4 25 minute sessions here in Texas. I’ve not had any issues. I ran last year and temps at the track were 105°. It’s all about how much power for how long...
-Don
747 RWHP 794 RWTQ
