Old 11-18-2009, 06:02 AM   #1
Ukd73
Drives: 2010 1ss/rs Ls3
stabili trak problem after 1st tune and skip shift elim.
Anyone else had a issue with the stabili trak saying need service after intsalling a diablo tune? I also installed the skipshift link and now it is HARD to get in reverse. That is all I did. Suggestions very welcome
Ukd73 is offline   Reply With Quote
Old 11-18-2009, 06:53 AM   #2
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
not sure about the stabili-trak issue but the with the skip-shift, you installed it in the wrong solenoid. Its on the drivers side shown in the picture. This is the correct solenoid:
Old 11-18-2009, 07:33 AM   #3
Ukd73
I checked it was on the driverside??? maybe bypassing the selnoid has somthing to do with it?
Old 11-18-2009, 08:06 AM   #4
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
When you have a custom tune done you should have them remove the skip shift in the actual tune. Works like a charm!
Erik@Torq is offline   Reply With Quote
Old 11-18-2009, 08:20 AM   #5
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
Can't you just disable the skip-shift w/ the diablo???
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 11-18-2009, 10:13 AM   #6
Sam Friedman
Sam Friedman's Avatar
Drives: 2010 Camaro 2SS
Ok, now I am scared to get the skip shift...should I be or is this a rare case?
Sam Friedman is offline   Reply With Quote
Old 11-18-2009, 10:29 AM   #7
rray200
Drives: 2018 Camaro 2SS 1LE
Why even bother getting a skipshift eliminator? Its really not intrusive at all. Just give it slightly more gas and the skipshift light goes away and smoothly shift to second.
rray200 is offline   Reply With Quote
Old 11-18-2009, 11:26 AM   #8
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
I've had zero issues with my SLP Skip Shift Eliminator. It's just a resistor inside an OEM style connector so maybe it's a bad resistor or maybe one of the legs of the resistor broke off. Sounds like a rare case to me.
Old 11-18-2009, 11:34 AM   #9
rudack
Rudack
rudack's Avatar
Drives: ABM 2SS/RS
Send a message via AIM to rudack Send a message via MSN to rudack
I have the same setup and no issues as of yet. Post something on the Diablo boards they might be able to address it?
Edit: Right now the Diablo doesn't touch the transmission I thought. It was coming soon last I read.
ABM 2SS/RS #33390
rudack is offline   Reply With Quote
Old 11-18-2009, 11:51 AM   #10
IROCanSS
Drives: 89 IROC 350
THE OP PLUGGED INTO THE REVERSE SELONOID. Common mistake b/c the plug is right there staring you in the face. Unles syou know, you would be like... oh thats it. Its not. The skip shift plug is hidden on top of the tranny. Go plug it into the right plug.
The SLP sse works like a charm and to anyone who says the 1-4 is not that bad is full o` crap. Its stupid and only comes on at the most inopportune times!
Old 11-18-2009, 11:51 AM   #11
BOBSS
Outlaw
BOBSS's Avatar
Drives: 2010SS
after a tune, you need to disconnect the battery for a bit. this will reset the ECU / PCM
BOBSS is offline   Reply With Quote
Old 11-18-2009, 11:53 AM   #12
Blue Demon
Blue Demon's Avatar
Drives: 2006 Corvette
I agree, it sounds like you put it in the wrong place. If you put it in the one easily accessable on the side of tranny and not the cramped one at the very top of the tranny you definitely put it in the wrong spot and that is what is causing your hard to get into reverse problem.
Blue Demon is offline   Reply With Quote
Old 11-18-2009, 11:57 AM   #13
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Yup, wrong one you got there
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-18-2009, 01:19 PM   #14
Partick
Partick's Avatar
Just took a big crap so I'm not full of it, and it's not that bad. First couple of days it was a little annoying but in the last 3k miles it has engaged maybe 1 or 2 times. You can shift to 3rd instead of 4th and not lug the motor as bad when it does come on.
Partick is offline   Reply With Quote
SLP Skip Shift Eliminators Available @ MarylandSpeed! MarylandSpeed V8 Bolt-Ons & Tunes 0 09-18-2009 01:50 AM
TUNE and Skip shift eliminator SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 05-12-2009 09:15 AM
