Old 04-19-2018, 07:44 AM   #1
Punisher73
Drives: 2011 Camaro LS
Frustrated with CAI, keeps throwing signal
I installed a CAI on my camaro (AF Dynamic).
I have checked all of the connections etc. and they are all tight and installed as per the instructions. It kept throwing the sensor.
I replaced the mass flow sensor on it because I read that there were certain ones that would always trip if a CAI was put on. I put on one that was rated to go with a CAI.
It is still tripping the sensor, any suggestions?
Punisher73 is offline   Reply With Quote
Old 04-19-2018, 07:59 AM   #2
Synner
Drives: cars
Return it and buy a name brand instead of a $100 Chinese special. When designed improperly it can throw the range of the MAF signal off or you have leaks in the system.
Old 04-19-2018, 08:14 AM   #3
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
Ahhh, the good old replace a bunch of sensors that work perfectly fine fix...
2010 Camaro 2SS/RS
BandRcAMARO is offline   Reply With Quote
Old 04-19-2018, 09:09 AM   #4
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Did you damage the connection on the cai itself? Also if you bought tune version of a cai that may also be the problem.
rontammy0 is offline   Reply With Quote
Old 04-19-2018, 10:15 AM   #5
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
This thing has been so problem free I sometimes disconnect the MAF just so I can experience a problem with the GM Z/28 CAI.
Moto-Mojo is offline   Reply With Quote
Old 04-19-2018, 10:23 AM   #6
DSMer1
Drives: 14 and 15 SS's
OP, don't throw the maf sensor, that can damage it!
Seriously though, what code(s) are you getting. Need more info to speculate on what is happening
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 04-19-2018, 11:06 AM   #7
MrChrisLS3
Drives: 2018 1SS M6
Is it an oiled filter or dry filter?
MrChrisLS3 is offline   Reply With Quote
Old 04-19-2018, 11:48 AM   #8
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
I agree with MrChrisLS3, if it's an oiled filter you could be getting oil on the MAF. However, like Synner said a reputable company like CAI, Rotofab, Vararam, Chevy's Z/28 intake, or even K&N would likely give you better results.
Check out my build thread
Old 04-19-2018, 12:38 PM   #9
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I'm just going to say this.. The basic concept of the intake is the same no matter what brand. Brand to brand some may flow better or give you better power but as far as throwing codes..they are all the same with the exception of cheap materials collapsing or something like that. Its a closed system. Check for leaks. That is number one. One of the most common ones is around the air flow meter on the tube.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 04-19-2018, 12:39 PM   #10
Punisher73
It's a dry filter.
Old 04-19-2018, 12:41 PM   #11
Punisher73
Reading about the AFDynamic and the K&N, they both look the same and are made with the same materials. Really don't think it is product quality issue as someone suggested.
I will go back through all of the connections again and see if something may have been missed.
Old 04-19-2018, 12:51 PM   #12
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
I am running the same intake. No issues. I was pleased with the quality of it.
2014 2SS/RS LS3/M6
Old 04-19-2018, 02:05 PM   #13
MrChrisLS3
Drives: 2018 1SS M6
Obviously double check for leaks, especially pre maf. Also check the sensor that is has a letter in front of the number. The lettered mafs are the stronger ones. Also make sure the maf is installed properly, if I recall correctly, it is directional.
Old 04-19-2018, 02:20 PM   #14
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Ive had K/N , and now own CAI , cold air inductions closed system, seen people with air raid, etc... nobody has ever had codes thrown for any reason, this is a user error, he either damaged the maf while removing it, and or screws aren't holding it so it might be rattling around, or a cheap brand cai is restricting the maf on the inside, or oil could be damaging it, but dry filters, never had ever any issue after day 1 of install, these things are bulletproof.. to use and install, i blame the user. , check your maf to being lose or damaged or wiring issue when you replaced it.
Hellfighter is offline   Reply With Quote
