Old 04-19-2018, 11:15 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
How much should boost vary with weather changes?
Working out a power loss issue on a buddys car. He made 10.5 psi @ 6500 when he was tuned a few months ago. Now we are seeing a MAX of 9psi at 7300rpms.
Hes running a P1SC and the tensioner is maxed. His belt is new.
Can a temperature difference of less than 20 degrees cause this drop in boost?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 04-19-2018, 11:26 AM   #2
hillshooter
Drives: 2015 Camaro SS commemorative
I will see a 2 PSI variant based on warm days VS cold days.
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 04-19-2018, 12:04 PM   #3
eLeSthree
Im guessing Utahs weather varies greater than Floridas. Im talking a difference between 85 and 65 degrees.
1158whp 1017wtq.
630whp 658wtq
Old 04-19-2018, 04:10 PM   #4
stevieturbo
Drives: it changes
Tensioner is maxed ? Are you saying it needs replaced or something ?
What does a graph of boost vs rpm look like ?
stevieturbo is offline   Reply With Quote
Old 04-19-2018, 04:13 PM   #5
hillshooter
haha yeah good point. we can be 100 or 0. I don't drive under 40 degrees though.
2015 Camaro SS
Old 04-19-2018, 04:34 PM   #6
AGP Turbo
Drives: All things Turbocharged
Clean the airfiler out and don't re-oil it. Turbo and Centri's don't suck air well at all, they are designed to blow it super efficiently.
AGP Turbo is offline   Reply With Quote
Old 04-19-2018, 06:55 PM   #7
eLeSthree
Theres a bolt on the Procharger tensioner to adjust tension. His is maxed out.
1158whp 1017wtq.
630whp 658wtq
Old 04-19-2018, 06:56 PM   #8
eLeSthree
Thank you Sir. I will do some pulls without the filter and report back.
1158whp 1017wtq.
630whp 658wtq
Old 04-20-2018, 08:06 AM   #9
eLeSthree
Does this look like belt slip?
1158whp 1017wtq.
630whp 658wtq
Old 04-20-2018, 08:34 AM   #10
ecreps
Drives: 2014 1LE, 1996 z28
Not to me, not a ton anyway. Fuel pressure is dropping off a little though...
Is there a bunch of belt all over the supercharger pulley? I wouldn't think you'd have a ton of slip with a P1SC even on a 6-rib setup.
ecreps is offline   Reply With Quote
Old 04-20-2018, 12:09 PM   #11
eLeSthree
No sign of belt dust, 8 rib, and i showed him how we can fix his fuel pressure but, he didnt think it was necessary. I flashed my fpcm with the zl1 specs and i hold 58psi to redline. He is on E85, ID1300x2, zl1 pump and bap, making 650.
1158whp 1017wtq.
630whp 658wtq
Old 04-20-2018, 01:55 PM   #12
stevieturbo
Drives: it changes
Perhaps a slight step on one part of the graph, but as above, boost graph looks fairly good with no huge obvious drops or levelling off to indicate a lot of slip.
