Old 04-19-2018, 12:00 PM   #1
2muchboost
Drives: Nissan
Fresh rebuilt L33 for boost
CONTACT INFORMATION:
Cell (Text Only Plz): 631.836.5927 (best way to reach me)
PAYMENT OPTIONS: Cash or Cash + 6.2 Bare Block
PRICE: See Below
SHIPPING: Not on the block at this time
L33: Price $1950 FIRM
  • L33 bored 0.020 over: Aluminum 5.3s that make over 800+rwhp in stock form.
  • 24x Reluctor and polished crank
  • New stock 0.020 over bore pistons
  • Gen 4 Rods with ARP Bolts
  • Total Seal Steel Piston Rings gapped for 24-28 lbs: $250 rings
  • Stage 2 BTR Turbo Cam
  • LS2 Timing Chain Set with Damper
  • LS7 Lifters and Trays
  • Manton 11/32 120 Wall 7.4 Pushrods
  • 317 Heads Milled 0.23 (9.6:1 compression if memory serves me correct)
  • BTR Dual Valve Spring Kit
  • ARP Head Bolts
  • Ported Melling 295 Oil Pump
  • Stock Rocker Arms
  • Stock Valve Covers
  • New Knock Sensors
  • All Engine Sensors
  • All Engine Covers
Bought off a fellow LSX member in Austin in December 2017. Machine work done by a shop in Central TX but the name escapes me at the moment. Only reason I am selling is because Uncle Sam gave me the shaft this year with taxes. I fought the case aggressively but got my notice on Friday that I am still screwed. I would rather this not sit in my garage as it may be a while before I can get back to the build. Everything is new with the exception of the block, crank, and heads. Similar setups have seen 800+rwhp all day.
If you are in TX and a reasonable distance, I may be able to travel to you but we can work out the details when you reach out. If you have a bare 6.2 block or 6.2 shortblock we can work that into the price.
2muchboost is offline   Reply With Quote
Old 05-01-2018, 12:42 PM   #2
2muchboost
Drives: Nissan
Shipping quote ranges from $200-250 depending on location through Fastenal.
Old 05-01-2018, 05:28 PM   #3
caper
Drives: 2010 IOM 2ss/RS
Stock pistons?
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 05-03-2018, 02:11 PM   #4
2muchboost
Drives: Nissan
Yes sir stock replacement pistons. Stock rods with ARP hardware as well. I am sure you are well aware how capable these little beasts are even in stock form. Was just looking at Capazzi's setup with the L33....spinning these puppies to 8k rpm is insane lol.
Old 05-21-2018, 11:48 AM   #5
2muchboost
Drives: Nissan
New firm price is $1950. Can ship out via Fastenal.
Old 05-21-2018, 01:46 PM   #6
ozzy1le
ozzy1le's Avatar
Drives: 2015 camaro 1le
Great price. Wish I was closer and ready. I have an lm7 in my turbo silverado that it would be perfect for.
ozzy1le is offline   Reply With Quote
