Old 04-19-2018, 06:24 PM   #1
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
AGP twin vs PD blower (Kenne Bell 2.8)
For anyone interested here is the power difference between the PD blower and twin turbos.
Background: My car is a 2014 1LE stock engine with a full fuel system on E85, ID1000 injectors and 3" exhaust through mufflers.
Both where run at 17psi
Turbos where 57/57 with .82 AR
scv_guy is offline   Reply With Quote
Old 04-19-2018, 06:28 PM   #2
hillshooter
Drives: 2015 Camaro SS commemorative
good post. How about seat of pants driving? that torque on the blower is incredible, i would imagine that would translate to the street fairly well.
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 04-19-2018, 06:31 PM   #3
Silver14
Drives: 2014 SIM 2SS
Thanks for sharing these results. Was the same dyno used?
Silver14 is offline   Reply With Quote
Old 04-19-2018, 06:32 PM   #4
scv_guy
scv_guy's Avatar
The blower is better suited for a street car...
Old 04-19-2018, 06:32 PM   #5
scv_guy
scv_guy's Avatar
Same dyno and settings.
Old 04-19-2018, 06:47 PM   #6
AGP Turbo
Drives: All things Turbocharged
Two things. Looks like a non loaded dyno so that's worthless for seeing how turbos spool up. We usually see 600wtq at 3600rpm on a real loaded dyno.
Those are pretty big turbos if you are worried about getting into TQ quick, those will make almost 1100whp.
Smaller turbos in .63 housings, ballbearing have much faster spool and still have made 840whp. Much more top end than a KB 2.8 can support. And all without crazy heat soak.
Sort of an apples to oranges comparo, guess you had way more turbo than you needed.
AGP Turbo is offline   Reply With Quote
Old 04-19-2018, 07:06 PM   #7
AGP Turbo
Your dyno is likely just a 2000lb roller and zips through a whole pull in a couple seconds. So you don't see where the turbos spool up in real world conditions and it went through so fast it didn't even show real peak torque at 4600rpm. I assure you would have been 60-80 higher than the peak you see.
Old 04-19-2018, 07:17 PM   #8
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
The dyno plot in a way shows how power comes on with each FI. Wow - I whole 135/76 difference between the two at the same PSI (parasitic and efficiency). But the SC has that low-end, whiplash torque down low that makes street fun. All until the turbo car spools up next to you where you're in the power band of 4400-6500rpms. Yippe ki ya!
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-19-2018, 07:57 PM   #9
ecreps
Drives: 2014 1LE, 1996 z28
Interesting comparison, are you running the stock cam?
I know it's been asked before, but can you give a rundown of how your fuel system works?
ecreps is offline   Reply With Quote
Old 04-19-2018, 07:58 PM   #10
ecreps
Do you know which turbos were used for this run?
Old 04-19-2018, 08:33 PM   #11
Scotty D
Drives: 2014 1le 1SS CRMT
Why is th PD better suited for the streets ?
Scotty D is offline   Reply With Quote
Old 04-19-2018, 09:03 PM   #12
scv_guy
scv_guy's Avatar
That is my opinion. Instant low end makes for a fun car!
Old 04-19-2018, 09:28 PM   #13
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Both setups require different cams. I see no added value other than showing why you need different cams.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 04-19-2018, 10:22 PM   #14
Scotty D
How are you liking the kenny bell?? And it fits under the hood vent ?? I also have a 2014 1LE
I really want the AGP twins but I’m on the fence !!
