04-24-2018, 09:46 AM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Coolant vent / crossover tube
Anyone know where to pick a coolant vent / crossover tube that connects to the front of both heads and to the radiator neck? I built one out of earls fittings and that leaks like a mofo.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
04-24-2018, 02:42 PM | #2 |
Drives: cars Join Date: May 2011
The stock one...?
04-24-2018, 05:17 PM | #3 |
Yeah I found a universal one, I made one out of a Earls fittings kit and it worked like shit leaking on my new build. The one for our cars has the vent tube to the radiator out the top, which during the time I built the earls kit was pretty hard to find. Summit has them now. Called the dealership they didn't have any and couldn't order any. Another dealership tried to order me the wrong part. Seems crazy for such a common part. Should have snagged the one off my LS3 before I sold it.
04-26-2018, 09:11 AM | #4 |
This is the one to use, which are typically not easy to find. Part #12602548 for the tube. I went to Ace hardware and got M6x1.0 bolts 30mm long for 67 cents a piece for installation instead of 8 bucks a piece from the dealership.
04-26-2018, 12:13 PM | #5 | |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
https://www.ebay.com/itm/05-11-LS3-L...sAAOxyB0VRyKbB
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
04-26-2018, 12:42 PM | #6 |
Thats the old part number, call a dealership without one and see what they come up with. Hence why I posted it so people can find the part if they are in the same situation and do a search here.
04-27-2018, 07:22 PM | #7 |
I just modified the stock one myself and never had an issue in 3 years. Where is the leak? Did you use o ring?
Car mods: never enough!
