Old 04-24-2018, 11:00 AM   #1
Mrbabe
Drives: 2010 IOM Camaro 2SS/RS LS3
Factory ground effects quad tips?
Good morning-
I wanted to reach out to see if anyone has done quad tips with the factory ground effects on the 5th gen. I think it would look great to have quad tips, just not sure about th end result with the gfx package. Has anyone done this, and if so, would you be able to share an example of the end result? Thanks everyone!
Mrbabe is offline   Reply With Quote
Old 04-24-2018, 11:18 AM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I don't believe the factory GFX kit opening is big enough for quad tips. I mean anything is possible with money and a body shop but it wouldn't work without some modification to the original kit.
SSEssence is offline   Reply With Quote
Old 04-24-2018, 02:04 PM   #3
cnrad
cnrad's Avatar
Drives: a wagon
Originally Posted by Mrbabe View Post
Good morning-
Here you go: https://www.camaro5.com/forums/showthread.php?t=164555
Looks like these are the tips: http://stainlessworks.net/y-exhaust-tips
cnrad is offline   Reply With Quote
Old 04-24-2018, 02:21 PM   #4
SSEssence
Instagram: Sangstah
I stand corrected, those look great!
Old 04-24-2018, 02:55 PM   #5
Mrbabe
Awesome, thank you!!
Old 04-24-2018, 03:49 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
Yea, Stainless Works has them. But I don't think it looks right. They are not like your normal quad tips.
The quad tips are a lot smaller and closer than what you would normally use with a regular diffuser. Plus, they are very hard to get lined up properly. Hell, even my square GFX style MBRP tips are a bitch to line up.
Quite simply, it does not give the same look as most try to get with quads.
But that's just my opinion...and you know what they say!
