Old 04-25-2018, 12:42 PM   #1
kalayed
kalayed's Avatar
Drives: Camaro SS
Unhappy Nitrous System (175HP) on 2010 L99
I have a 2010 ss with L99 engine,
it has Vararam air intake, 102mm throttle body, Holley intake manifold, TSP headers and Corsa exhaust, and it made about 380 rwhp and I'm not satisfied at all with it. So I made a decision on getting a 175HP Nitrous system.
So, do I need a torque converter or any other parts?
kalayed is offline   Reply With Quote
Old 04-25-2018, 02:11 PM   #2
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
oh how the nitrous post's never cease to amaze me....
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 04-25-2018, 04:15 PM   #3
AGP Turbo
Drives: All things Turbocharged
Wet shot. ZL1 pump and a tune to make it all work right.
Converter is only going to make it hit harder off the line if you have the traction.
AGP Turbo is offline   Reply With Quote
Old 04-26-2018, 07:53 AM   #4
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I put a Maggie on my L99, big difference. No dyno but should have ~ 560hp.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 04-26-2018, 09:50 AM   #5
UBB
UBB's Avatar
Drives: 2018 ZL1
which one?
Nevermind, read your sig.
UBB is offline   Reply With Quote
Old 04-26-2018, 11:37 AM   #6
Punisher_ATX
Drives: 2010 SS
I wouldnt spray more than a 100 shot on those AFM lifters lol. Asking for trouble.
Punisher_ATX is offline   Reply With Quote
Old 04-27-2018, 12:53 AM   #7
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
The most nitrous I have seen anyone spray on a L99 was a 150hp shot and that was with a ZL1 fuel pump and a good dyno tune. Definitely use a wet shot and don’t get a higher rpm torque converter keep your stock torque converter in there as it will just make your situation worse. Consider upgrading your tires and suspension as this will help you get traction when spraying nitrous.
Mr. Clean
Blueovalman is offline   Reply With Quote
Old 04-27-2018, 03:16 PM   #8
WoodBoss
"Old School"
Drives: 2010 2SS L99
I have been spraying a 125 HP Shot for a while on my L99. It works good but that is the max without upgrading the fuel system. You will like it and see a huge difference. I would advise you to start with a 100 shot and go from there. I use the stock converter and like it that way. If you checkout my youtube channel in my signature, I have videos showing the nitrous install and what you have to consider. I have some runs at the dragstrip as well. You will need a tune, different plugs, a bottle heater and a purge kit is nice too. I bought the ZEX kit for the 2010 Camaro and it uses a wire on the throttle body to trigger the nitrous & fuel solenoids. Steve from RDP motorsports provides my tunes and reviews my data logs. Good luck and if there is anything i can help you with just ask.
WoodBoss is offline   Reply With Quote
