anybody have a lowered 1le?
i have a 15 1le. all the bmr stuff in the rear end and nitto 01's all the way around, other than that stock suspension. so my questions are. will lowering 1 inch all the way around improve handling (bmr kit) or is there another brand that everybody loves more. thanks
![]() Drives: 2015 SS/RS 1LE Join Date: Dec 2014
If you only want to go an inch, you basically have two choices; BMR and Hotchkis are the two companies that most people use. Improve handling, that's somewhat opinion, most people say yes but it has never been verified on a 1le with track times.
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
I have the H&R 1.4/1.3 springs. I love them. Handles much better, tighter on the street... no track times though. I read some threads of people complaining about bmr not lowering the car enough... barely noticeable... that's why went with the H&R springs.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
any negatives to lowering?
Only when you hit big bumps...less forgiveness
#6 |
![]() Drives: White 1le 2SS RS NPP Join Date: Mar 2015
I went with the pfadt 1.25 inch lower springs. They are now sold under the brand apex and the car rides better than stock
#7 |
Handling will always improve on any car when lowering, but depending on use could make for an uncomfortable ride based on use.. The real question you should be asking should be fully based on what you do with the car. We don't know what's your use of the car is so it's hard to tell you your options and how they relate or compare.
Are you just out cruising around on the street and occasionally getting on it or are you trying to go full pro street?? Are you only track dedicated and occasionally street driving? Are you street to strip? As you see so much questions based on what you are using the car for. What are you using the car for and or future use ...?
Car mods: never enough!
#8 |
just street for now. maybe autocross someday
#9 |
Coilovers if you can swing the cost. These will set you in best position to change height or dampening base on what your doing that day.
Drop springs if your looking for budget friendly but your stuck at one height and have no dampening options. Both will work better than keeping stock height though. .
#10 |
![]() Drives: 2015 SW 2SS 1LE Join Date: Jan 2018
I will be installing Pedders extreme XA remote canister coil overs in the next few weeks for running the Mile. I want to be able to lower it as much as possible to have lees air under the car and then raise it up for the street.
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
#11 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Lowered mine around 1 1/4" with BC Racing ER Series CO's. With CO's, you can chose a range of adjustment to suit your needs from 0 to around 1 1/2+".....And as to the comment about lowering the car for aero purposes, I don't think it's just as simple as "lower is better". Airflow doesn't seem to be an easy issue.....
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
#12 |
You are correct sir. Airflow on these cars is not all about "low",but the OP's question was about lowering. I tape the grill, remove side mirrors and rear spoiler and few little things under the car as well.
#13 |
![]() ![]() ![]() Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
I just lowered mine with 1.25” BMR spring looks killer !!
#14 |
Eibach sells springs as well for these cars that drop it approx an 1"-1.25"
