![]() Drives: 2010 1ss/rs Ls3 Join Date: Oct 2009
how long do you leave the battery cable off to reset the ecm
This stabilitrak crap is killing me I was wondering how long do you leave the battery disconnected for the computer to reset?
thanks |
![]() Drives: 2011 CTS CPE & 2010 2LT/RS CGM Join Date: Jun 2009
Probably for only 2 minutes to erase the volitile memory but to be safe 15 minutes. You don't have to disconnect the battery. In the fuse box that is located in the engine compartment, you will find 2 fuses for the ECM. Just pull those two fuses and you will not loose your clock and radio Presets. I think they are red top fuses (10 amp)
Institutionally Insane
Why do you need to reset the computer?
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
my stabilitrak light wont go out so I was thinking I could reset it. my friend unplugged the reverse selnoid, thought it was the one for the skip shift but not. Now I have the stablitrak lights on saying needs service. if anyone has a better solution other than the dealer it would be great.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
disconnect the battery cables and hold the + and - ends together for 5 seconds and your good to go immediately.
#6 |
![]() Drives: 05/07 Chevy's Join Date: Aug 2009
| Bumleb's Camaro battery cable issue is almost Fixed, Issue Solved | Bumleb | 5th Gen Camaro SS LS LT General Discussions | 118 | 05-15-2009 12:04 AM |
| Battery Cable Issue? | Scott@Bjorn3D | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 17 | 05-06-2009 12:25 PM |
| Camaro5 T-Shirts, Long Sleeve, Sweatshirts, Hoodies FOR SALE!!! (CLOSED) | TAG UR IT | Camaro5 Store Merchandise | 122 | 03-31-2009 01:06 PM |
| GM To Build Battery Plant | Mr. Wyndham | General Automotive + Other Cars Discussion | 5 | 01-13-2009 02:03 PM |
| Chevrolet Volt | Urthman | General Automotive + Other Cars Discussion | 160 | 09-29-2008 09:17 PM |
