Old 04-26-2018, 06:21 PM   #1
hillshooter
Drives: 2015 Camaro SS commemorative
MAX HP forged internal LS3. 2018 edition
Let me start off with what I know. these are for the keyboard warriors.
1. Yes this is a searchable thread but I would like to know what we have learned since 2010.
2. Of course, there are many factors and its complicated. We don't need to hear that.
3. "Depends on the tune"......Really, I am sure its tune dependent. 600 horse is tune dependent so I am sure 1200 is going to be as well.
Ok now in all seriousness. What have people seen out of the stock block? Either Stroker or not with good forged rotating components. Does anyone think 1500 Flywheel can be done?
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 04-26-2018, 07:22 PM   #2
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Could be and should be are different things. If aiming that high, I'd start with an iron block.
Unavowed is offline   Reply With Quote
Old 04-26-2018, 09:08 PM   #3
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Not if, but when I pull the suction restriction plate I will be sitting at 1100 RWHP so if you add back 25% loss from the flywheel then I would be at 1375 flywheel on a stock bottom end so is it possible? Yes, but how may pulls will you get before something lets go is a roll of the dice each time.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 04-26-2018, 09:57 PM   #4
hillshooter
Isn’t yours a manual? Good info but I think 25% is steep for that’s setup. Pull that plate and let’s experiment together !
2015 Camaro SS
Old 04-26-2018, 10:12 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I thought the accepted was 15% for M6 and 20% for autos. I just use 20% regardless when doing math in my head because it is easier.
Old 04-27-2018, 10:19 AM   #6
BiggFoot
BiggFoot's Avatar
You know, after thinking about it I am sure you guys are right. It is certainly less for a manual vs an auto, but a loss of 25% is too much for a manual. Honestly, its only a number so its not something I really consider much. I mostly go by sense of acceleration upon a step change in HP and then eventually a time slip but even that doesn't tell all because I suck as a "drag strip specialist" and that's the truth of it. I don't go to the strip often enough to get "good" at it.
Blower Cam
RPM Level VII
TR6060
Old 04-27-2018, 10:24 AM   #7
Unavowed
Unavowed's Avatar
Back on topic, when heads start to lift and cranks start to walk, you'll wish you had an iron block with 6 bolt heads.
Old 04-27-2018, 10:32 AM   #8
hillshooter
I all ready wish that and when I blow this lS3 up I will have one I am sure
2015 Camaro SS
Old 04-27-2018, 11:02 AM   #9
BiggFoot
BiggFoot's Avatar
I have 6 bolt heads, but no iron block. Like Hillshooter . . . maybe someday.
Blower Cam
RPM Level VII
TR6060
Old 04-27-2018, 11:18 AM   #10
hillshooter
did you weld on the stock block to accept the 6 bolt heads? got any pics?
2015 Camaro SS
Old 04-27-2018, 12:36 PM   #11
BiggFoot
BiggFoot's Avatar
My understanding is they just bolt up, no modifications necessary. I was told these could even be used on a 427 if I choose to go that route later on. I should probably ask more questions but I just want the car to haul azz when I mash the accelerator.
Name:  Brodix Heads 6.jpg
Name:  Brodix Heads 7.jpg
Name:  Brodix Heads 18.jpg
Blower Cam
RPM Level VII
TR6060
Old 04-27-2018, 01:12 PM   #12
bct10985
Drives: 2010 2SS LS3, 2013 duramax
6 bolt heads do nothing on a 4 bolt block.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 04-27-2018, 02:32 PM   #13
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
They look pretty though
1100whp seems to be the limit where aluminum blocks are used
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-27-2018, 03:07 PM   #14
hillshooter
1100 through the auto would be great.
2015 Camaro SS
