![]() Drives: zl1 Join Date: Nov 2016
Twin turbo or superchager upgrade
Dears
I have 2013 ZL1 automatic gear currently 630 rwhp Which is better for me to go more; twin turbo or supercharger upgrade? My current setup Long tube headers Lower 10inch pully JLT Intake filter 1050 fuel injectors TR7 Spark plugs Heat exhanger with fans Throttle body upgrade GT11 CAM |
![]() Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
what are you goals and plans with the car?
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
![]() Drives: ZL1 Convertible Auto Join Date: Apr 2015
I had a pretty similar set up, just added E85 and a 2.75 upper pulley, ported blower and snout. That was a small gain. Now I am going with a Huron Speed twin turbo set up. I expect to do a high 9 in the 1/4
https://huronspeed.com/
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
#4 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Magnuson Heartbeat or Whipple 2.9 upgrade, more boost with less heat. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
![]() Drives: ZL1 Join Date: Dec 2016
Depends on what you are doing. If you are basically running the 1/8th mile or even a 1/4 drag racing. I see lower horsepower blower cars run better e.t.'s than most turbo so often. If you want dyno king a turbo is the way or a roll on or 1/2 mile to 1 mile car go turbo.
