Old 05-02-2018, 02:25 PM   #1
LETHAL2SS
LETHAL2SS's Avatar
Drives: 2011 Camaro 2SS
Rev Hang?
2011 camaro 2ss M6, Into neutral coasting even at 5mph, revs hang around 2k rpm until I push in the clutch, any ideas why this would be happening.
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp
LETHAL2SS is offline   Reply With Quote
Old 05-02-2018, 03:21 PM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
ported tb is what i've been told... same thing happens to me
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-02-2018, 03:29 PM   #3
cypressh
Canadian
cypressh's Avatar
Drives: 2011 Camaro 2SS/RS
I had this happen, if you take it to your technician and have them do a crank relearn procedure it will clear up
2011 Camaro SS/RS
The cars we drive say a lot about us.
cypressh is offline   Reply With Quote
Old 05-02-2018, 03:30 PM   #4
Hippy
Hotwheels
Hippy's Avatar
Drives: Hotwheels Edition
Send a message via Skype™ to Hippy
After a couple years with a ported tb with out any issue (so I'm not with you there)
I noticed mine acting simular to what your stating. My rpm seems to only be 1400 or so and seems to take a noticeable difference in time to come down to normal idle.
And also affected went clutch is out or depressed.
Just noticed it this weekend so I haven't checked into it yet.
Quirious to see what's think the cause is.
Sent from my SM-G955U using Tapatalk
Parts for Sale
2013 2SS Hot Wheels Edition 734 of 1524
Hippy is offline   Reply With Quote
Old 05-05-2019, 01:56 AM   #5
OmarAlansari
Drives: ‘10 Red Camaro ss
Any fix? Having the same problem.
OmarAlansari is offline   Reply With Quote
