![]() Drives: 2013 2SS M6 Join Date: Mar 2018
LS3 - Is 550whp all motor feasible?
So after a custom cam and TSP longtubes, my car made 470hp/440tq at the wheels. Next I'm throwing on a CAI and getting the heads ported to try and hit the 500 number. If that's all it takes to hit 500, what gains do other mods add? What would I see with a FAST intake and ported throttle body? People seem to say the FAST isn't worth the money unless you get a cam and ported heads. What if I do have a cam and ported heads? Am I going to lose bottom end torque with the intake?
After 500, I'll be looking into all of the little mods. What else should I consider? I know people push 600+ with FI. Do I face any longevity issues pushing it as far as it can go NA? And it seems like people break axles on these cars somewhat frequently. What's up with that? Bad production run, too sticky tires, the fact that the factory launch control is set to 4k?
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
![]() Drives: 2010 Camaro 2SS Join Date: Aug 2016
Gpi max head cam package seems to be the most power I've seen N/A from a stock bottom end ls3
#3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Mar 2013
You can do it, yes.
In a car as heavy as the 5th gen... meh. Go too big on the cam and you're losing power under the curve, and drivability really suffers.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
how fast are you going to spin the motor? if you spin the motor above 7K the fast 102 may be better but a rod-mod intake manifold is difficult to beat when staying under 7K rpms.
check this out for more info and the flow test: https://ls1tech.com/forums/generatio...ast-102-a.html also, if you're going all-motor why not consider itb's? expensive yes but the gains appear to be pretty damn good edit: as for the loss of low-end power/torque you can swap in a shorter (numerically higher) rear gear and get back some of the lost wheel torque due to the cam and other mods
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#5 | |
but is there no air filter?
#6 | |
but! if you're sticking to under 7K RPM i would get a rod-mod manifold
2010 2SS/RS
#7 |
![]() ![]() ![]() ![]() Drives: 2015 1LE Join Date: Oct 2015
Just stroke the motor and it will be much easier.
#8 |
I've thought about it, but if I'm going to drop the money on a stroker kit + labor, I might as well go for forged pistons and rods. And at that point I'd expect to pay upwards of $10k.
#9 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
Mast Medium bore LS7 heads
MSD atomic airforce intake manifold 102mm throttle body ARH special order 2" -> 1.875 -> 1.75 stepped longtube headers 2.75" or 3" exhaust (z28 npp works) PMAS 120mm cold air intake ZL1 or LS7 injectors flex fuel sensor wide band sensor fuel rails for MSD intake ZL1 fuel pump or better e85 Proper valvetrain (cam, valves, x ratio rockers) reduced ratio pulley normal maintenance/seals/gaskets 3 bolt timing chain + gear w/ the cam if done right, you have a shot at squeezing 600whp. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
What are you trying to accomplish ? Is it a DD ? Are you just chasing a number? If you want to go fast in the 1/4 a 3800 pound car is going to need a lot of RWHP and the right gears and be able to hook up . If that is you goal ,a little spray go's a long way and is dirt cheap.
OLD GUY FLYING FAST AND LOW
#11 | |
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
#12 |
![]() Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
Yes it is possible to get 540-550 rwhp naturally aspirated if you change to the LS7 set up with 2.5-3.0” exhaust,fuel system,intake set up with a dyno tune etc. The most I ever seen with the LS3 set up with full bolt on’s and a custom camshaft was 470-475 rwhp. You could always try a nitrous set up when it is controlled it is safe to use.
Mr. Clean
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
alot of cylinder head, compression and camshaft yes.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#14 |
Well you can achieve most by doing a great bolt on set up, get near 480 then add good heads, intake and cam it for 75-7800 shifts. You can achieve well over 550 with a good 13:1 compression on E85 if available or a good fuel like C85 or CHP for the track (like $70 for 5 gallons) If your limited to 91 then 11.5:1 will have to do and sacrifice a few big ponies. great thing about the aftermarket heads is valve angle for added piston to valve clearance. I will be chasing 530 cam only and 9s for my goal when I go that route.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
| Tags |
| 500, all motor, ls3 |
