Old 05-03-2018, 03:57 PM   #1
Tortugas12
Tortugas12's Avatar
Drives: 2013 2SS/RS Convertible
Drop springs
What drop springs do you guys have? Since the verts weigh more than the coupes I'm not sure what springs to get. Most pictures and measurements I've seen are for the coupes.
Sent from my SM-G965U1 using Tapatalk
Tortugas12 is offline   Reply With Quote
Old 05-03-2018, 04:04 PM   #2
SteveM12065
Drives: 2013 Summit white 2ss RS L99 conver
I'm interested as well. This car has a lot of body roll and id like to eliminate some of that.
Sent from my Moto Z (2) using Tapatalk
SteveM12065 is offline   Reply With Quote
Old 05-03-2018, 10:48 PM   #3
ex ford guy
ex ford guy's Avatar
Drives: 2011 conv 2ss/rs
These... https://eibach.com/us/i-3312-pro-kit...4-springs.html
ex ford guy is offline   Reply With Quote
Old 05-04-2018, 07:13 AM   #4
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Hotchkis 1” drop springs. I have had them on for 5 years now. Back then they had a specific convertible set. I don’t see them listed anymore. As I recall, there was no difference in psi between the coupe and the convertible. Call Hotchkis.
SS PANTHER is offline   Reply With Quote
Old 05-04-2018, 08:01 AM   #5
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
Just do air lift performance bags they will ride better then any coil or spring and handle better
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
Old 05-04-2018, 01:29 PM   #6
b4wheeler
b4wheeler's Avatar
Drives: 2011 Camaro 2SS Vert
Bring yours out East. I want to see a Vert on AIR....... (decision maker)
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
b4wheeler is offline   Reply With Quote
Old 05-06-2018, 05:23 PM   #7
Abelardoo_12
Abelardoo_12's Avatar
Drives: 2011 camaro ss convertible
Ive had the BMR 1 inch all around for about two years with no problems. I talked to BMR on the phone before ordering and they told me to order a 1.25 for the front because the back was heavier and would sit lower but I decided to get the 1 inch all around and it sits even.
Abelardoo_12 is offline   Reply With Quote
Old 05-07-2018, 07:53 PM   #8
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
I'm going to drop mine too. Thinking about 1.25 front and 1.00 rear. Anyone have this setup with pics? I am concerned about my rear suspension with it lowered. Not sure if the squat will start breaking stuff, like axles...
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 05-08-2018, 06:49 PM   #9
llcamaro
llcamaro's Avatar
Drives: 2011 Camaro SS/RS Convertible
Eibach 1 " springs with Hotchkiss sways
[IMG][/IMG]
Let the mods begin,
LG Pro LT's, HF Cats, Borla Touring Mufflers, CAI intake, American Racing Tunnel Brace, Eibach 1" springs, Hotchkiss sways, Mickey Thompson Wheels and Tires
llcamaro is offline   Reply With Quote
Old 05-18-2018, 09:55 PM   #10
Screwblower
Drives: 14' 2ss convertible
BMR 1 inch drop. Mine sits even front to back. Fender lip about half finger width above the tire.
After 5k miles on the springs it rides better. Reduced roll.
I went with MMR wheels 275 fronts / 315 rears.
I do not autocross, so no need for bigger sway bars.
Screwblower is offline   Reply With Quote
Old 05-20-2018, 12:07 AM   #11
ROKDWLR
ROKDWLR's Avatar
Drives: 2015 Camero LT Convertible
I just installed the 1.5/1.4 X5 springs from Phastek on my 2015 LT vert along with staggered MRR M017 (275/315), vented slotted rotors & ceramic pads. After driving around the block with the bushings loose to index them, the rear sat 1.25" lower than the front. From the ground to top of fender: 29 front 27.75 rear. That's with an empty trunk. Contacted customer service & they're sending some 1" rears to swap out. Hopefully that will do the trick.
ROKDWLR is offline   Reply With Quote
Old 05-20-2018, 11:04 PM   #12
SS PANTHER
SS PANTHER's Avatar
You want to measure from the bottom of the wheel, outside lip, to the top of the fender arch. Too many differentials measuring from the ground. The factory height would be approximately 675-685mm high. Too low will put undue stress on your suspension. With a 1” drop this should be in the 25.6-26" (650-660mm) range. At this height there is no undo stress on the suspension geometry, especially the rear shafts.
Old 05-21-2018, 10:21 PM   #13
ROKDWLR
ROKDWLR's Avatar
Thanks SS Panther. Using that method I have 26 1/4 on the front. The rear is on jack stands & taken apart so I can't measure that yet. The new springs will be here Friday & I'll have it back together Saturday morning.
Old 05-27-2018, 05:33 PM   #14
ROKDWLR
ROKDWLR's Avatar
The 1" BMR rear springs worked great. It sits perfectly level now. 1.5" front & 1" rear. I'll get a picture up by morning.
