05-03-2018, 10:09 PM | #1 |
Quieter cold start?
Quick overview of the situation: My L99 has full exhaust now (long tubes, x pipe, mated to a borla atak system).
My neighbor has mentioned that when I cold start, it is so loud that it shakes/vibrates his bedroom windows and doors. Anyway, I was wondering if there's any way to make a cold start in these cars a little less violent? I love the way the car sounds otherwise, but cold starts in the morning are a little insane now. |
05-03-2018, 10:17 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
move? lol sry...good luck mate!
peace
05-03-2018, 10:47 PM | #3 |
Drives: 2013 Camaro SS Join Date: Oct 2016
Park it inside and start it in the garage.
05-04-2018, 07:19 AM | #4 |
You could change the way you park. I'm stock so startup sounds like an old man clearing his throat.
05-04-2018, 07:38 AM | #5 |
Started#gottalovethatblue
^^^ This. When I get ready to leave for a show early in the morning I do this. However, your neighbor is being a whiny baby and extremely over dramatic. Unless his house is about to fall down, there's no way you're vibrating the doors in his house. He may perceive a little airoverpressure difference in the windows for an instant, but noway are you shaking his doors.
05-04-2018, 08:55 AM | #6 | |
...and fortunately my neighbors don't f with me...lulz....peace!
05-04-2018, 09:04 AM | #7 |
Drives: 2014 2SS/RS Join Date: Jan 2014
Back in so your exhaust isn't facing his house?
05-04-2018, 10:23 AM | #8 |
Drives: 2010 Camaro 2SS LS3 Join Date: May 2012
Stock tuning has the timing retard ALLOT at cold start to heat the cats faster which falls under the ultra low emissions requirements, retarded timing makes exhaust loud since less combustion energy is pushign the piston down... that extra energy is being wasted out the exhaust. You could tune that part out. I just did this since I installed headers and removed cats, and only have short JBA straight through axle back (not chambered mufflers). So by increasing timing to normal when cold, it's much quieter on cold start.
If you have no cats, then this table should be 0'd out. Even if you have cats, you can 0 this table. The cats will just take more time to warm up. Last edited by dookie454; 05-04-2018 at 10:35 AM. |
05-04-2018, 11:13 AM | #9 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Its not "really" loud unless you set of proximity alarms when idling through a parking lot, chuckle.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
05-04-2018, 12:34 PM | #10 |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Tell your neighbor to grow some balls.
05-04-2018, 08:46 PM | #11 | |
Interesting information. I no longer have cats installed, so maybe this could be an option. Thanks. |
05-04-2018, 08:55 PM | #12 | |
Yeah, I already use the garage. I was thinking of keeping the garage door closed before starting up, and opening it right after the initial burst of thunder. Just concerned about exhaust fumes getting into the house (attached garage). |
05-04-2018, 09:54 PM | #13 |
Don’t keep the garage door closed. Literally fire the car up and immediately open the door. The initial bang of the car firing up will be muffled but you shouldn’t have any more fumes than if the car was idling in the garage for a few minutes with the door open.
05-04-2018, 10:34 PM | #14 |
Winner, this is your best option.
