![]() Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
Help with Boost Gauge and Blow Off valve vacuum
So I have a Kraftwerks supercharger that I installed. From their instructions, I cut the vacuum line on the drivers side of the throttle body and put in a T to the blow off valve. I placed another T there for the boost gauge and noticed I am not getting much boost. Like 3.5 PSI at 6000 and it makes boost very late. Where is and how is everyone putting their boost gauges in. I will be checking for boost leaks checking the blow off valve, but Kraftwerks has mentioned that maybe I want to put the gauge somewhere else too. Any ideas? Kraftwerks also says between 5 and 7 PSI is normal so I feel I may be short. I will also test with another boost gauge to be sure of what I am seeing. Eliminate the easy first.
![]() ![]() Drives: 2012 SS/RS MN6 Join Date: Mar 2016
I'm running a vacuum block.
Are you running that from the one vacuum line? Do you have any pictures? Maybe it doesnt matter that they are on the same leg. I was just wondering what others have been doing if they have seen the same issues.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
I have like 5 things tied into the same vacuum source, it shouldn't matter
OK I will move on to trouble shooting then. Look again for boost leaks check the gauge and vacuum line with another gauge. All of that fun stuff.
#6 |
![]() Drives: camaro 2ss/rs Join Date: Jun 2017
Krapwerks sent me the wrong blower in my kit, they sent me a c38-81 never made more than 1.9pounds of boost at 6300rpm costing me dyno tune time/money. Make sure you got the c38-91/92 even then I'm barely making 4.5 pounds of boost. I checked everything out & I have no leaks
5th gen BTR turbo 3cam, AGP twin 57s /E85/fore dual 450s/vaporworx controller
19 SS Huron speed twin 62/62 turbos 18 ZL1 2650 / port / Holley / New Era Performance stage 3 pd cam / Frankenstein ported heads 9.4 @ 151 3500da @stalk_zl1 |
#7 |
What did you make for HP and what are your mods. They advertise 600 crank which to me should be about 525 RWHP. I havent got it on the dyno yet but I am not seeing the boost like it sounds like you arent. I will be testing the gauge the vacuum line checking for boost leaks. They also say between 5 and 7 PSI, but it seems like 5 would be a reasonable amount.
#8 |
![]() Drives: 2SS/RS L99 ABM Join Date: Aug 2009
I’m surprised theses kits actually sell with the small blower they come with at the same price as an ecs kit?
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
#9 |
No pictures on this phone. But it's a Vibrant block. Running it off the brake booster.
#10 |
My kit was very affordable but I wished I had talked to Jannetty before buying it I may have gone with the smaller pulley larger injectors and been more of what I expected.
#11 |
![]() ![]() ![]() Drives: it changes Join Date: Nov 2010
