Old 11-19-2009, 10:15 AM   #1
bbfn11
Beeliever!
bbfn11's Avatar
Drives: 2010 2LT Coupe Automatic
How to access rear dirvers side fender for dent repair.
I have a ding just below the rear passenger drivers side window. It's just below the fold where the metal bends down towards the wheel well or fake gills. I don't have a camera available for a picture so sorry for that. What I want to know is what is the best way to access this area for paintless dent repair? The tech has never worked on a 2010 Camaro and I didn't want him pulling stuff apart until he get's knowledge of what to do first. would he go through the trunk or would have access pulling molding off the drivers side and entering from there? Anyone out there with knowledge on this?
bbfn11 is offline   Reply With Quote
Old 11-19-2009, 10:44 AM   #2
NVMY68SS
Drives #296
NVMY68SS's Avatar
Drives: 1968 Camaro SS - 350/5 Speed
Probably start by removing the plastic wheel well and see if that get's you in the area...........
#296 Delivered 6-1-09 Dynoed 10-3-09 384.56HP 387.65TQ with the bolt-ons listed, no tune.....yet!
Roto-Fab CAI (Install pics here), Doug Thorley Shorties, Flowmaster American Thunder 409S Cat Back Vid
NVMY68SS is offline   Reply With Quote
Old 11-19-2009, 10:49 AM   #3
bbfn11
Beeliever!
bbfn11's Avatar
Thank you for the reply. Is that accessed by removing the rear wheel and some screws. How is the plastic wheel well removed?
Old 11-19-2009, 11:05 AM   #4
bbfn11
Beeliever!
bbfn11's Avatar
Here is a picture of the dent. If this helps.
Old 11-19-2009, 03:08 PM   #5
ffrcobra_65
easy access. Up from the wheel well area. If not, removing the panels from inside the trunk might just be the ticket. Either way, not worth worrying about it. The PDR guy will get to it even if he has to drill a small access hole where you can't see and put a nice plug on in after.
Stop worrying. I know how you feel, I had a dent on the passenger side front fender and I worried and worried. PDR guy found a way to get behind it without drilling and after 10 minutes, good as new! And all the worrying was a waste of energy and sanity.
Old 11-19-2009, 04:09 PM   #6
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
Normal practice will be to drill a hole in the door jamb above the striker plate and access through that and put a rubber plug after (BMW pioneered that so I have been told)
Anyway like you I had a ding 2 weeks after i got it , on the wheel arch. The guy i took it to didn't want to do the 'normal' method on mine (thankfully) and elected for another slightly longer way of doing it. He removed the plastic wheel liner and had to drill through the first metal skin then popped the dent that way. Would never know its been done - and charged the same $75 -- seems to be about the norm for a ding.
markmass is offline   Reply With Quote
Old 11-19-2009, 04:37 PM   #7
Batman0837
Drives: '10 CGM 2SS/RS # 71394
I would fix that one with a glue pulling device to avoid the "normal" practice of drilling a hole in someone's car. Also probably doesn't take more than 15-20 minutes to get the interior trim out of the way to access the dent from the inside. Drilling should ALWAYS be a last resort.
Batman0837 is offline   Reply With Quote
Old 11-19-2009, 05:28 PM   #8
ffrcobra_65
I agree, drilling as last resort but really, it is not a bad thing if it comes down to that. Look in the trunk and engine bays of most cars and you will see plugged access holes. For instance, look at the rear spoiler nut access holes, they are covered with rubber plugs. A PDR access hole would look exactly like that and you it will probably be at a place where no one will see. If the panel is double skinned, just might have to drill.
Old 11-19-2009, 10:15 PM   #9
bbfn11
Beeliever!
bbfn11's Avatar
Thank you for the replies. The DPR tech said that he got a diagram from GM and said that to access the dent he will have to remove the back seat and plastic panels from the back drivers side.
I looked at the trunk access and there is an opening towards that area but I only saw more fabric of some sort (noise dampening material?)
I am not too worried about it. I am already over the shock of the dent. I will ask about the glue pulling but there is a slight crease in the dent so I do not know if glue pulling will get that out as well. I can only hope that this tech at the dealerships recommendation is skilled enough to tear it apart and put it back together. That is more of my concern now than the dent itself because I don't want that to become a problem after the dent is fixed.
I am scheduled to have it done on Dec 3rd.
Old 11-20-2009, 04:46 PM   #10
Batman0837
I am not against drilling (I do PDR repairs for a living). But I am against it when it is done out of laziness or time constraints especially when someone owns the car...If someone drills a car that is under warranty, you pretty much just nullified your corrosion protection warranty for that area of the vehicle. The only time I drill someones car is if the customer allows it after full disclosure of what comes along with drilling and all other options have been exhausted.
Good luck with the repair in December. Hopefully the dealer refers you to an experienced tech. A good sign of this is if he offers you a few options on how he will approach the repair, before reaching for the drill. If he goes straight for the drill, I would pass. It's one thing to know how to get to a dent, but there are several levels of skill as to how the dent will actually turn out when the tech is "finished."
Old 11-21-2009, 07:41 AM   #11
bbfn11
Beeliever!
bbfn11's Avatar
Yea, thanks for the good luck Batman. This tech is the dealers PDR go to guy he comes every Thursday to the dealership and handles all of their PDR's. And he did look to see which way would be the best way to proceed. He never mentioned drilling. But I wanted to make sure he knew exactly how to get at the ding so I made him get some more info. That is why I have to wait till Dec 3. Since he has never worked a new Camaro I wanted him to make sure he knows how to get at the dent, which he now does, before he repaired it.
Old 12-01-2009, 01:01 PM   #12
bbfn11
Beeliever!
bbfn11's Avatar
So to update my situation I had my dent fixed today and it turned out really well. I can't even see where it was damaged.
I did not go the DPR tech I originally had set up to do it. I went and got another estimate at a Dent Doctor located in Appleton and was quoted $50 cheaper. Not only did he do it cheaper he was able to access the dent from the rear seat drivers side panel. He just had to move it out enough to get his tools in and did not have to remove anything. The panel moves out of the way nicely to get at the quarter panel metal and there was an area for the tool to access the dent without drilling. Only took about an hour. I was very pleased with the service and quality of work. They also do work for the area dealerships which made my decision to go with them easier. I hope this helps anyone else who has an issue like I had.
Old 12-01-2009, 02:48 PM   #13
DangerZL1
Drives: 2023 Black ZL1 Auto
That's great news to hear the tech got all of it out, and for less $.
DangerZL1 is offline   Reply With Quote
Clear front and rear side turn signals (Any vendors intersted?) TAG UR IT Cosmetics and Lighting Modification Discussions 34 12-25-2009 12:36 AM
Aftermarket Fender / Side Skirts ? Robersabel Cosmetics and Lighting Modification Discussions 16 07-27-2009 04:14 PM
Rear Side windows Hillbilly 5th Gen Camaro SS LS LT General Discussions 2 05-17-2009 07:56 PM
My camaro is here but Needs a new drivers side fender Jferrell88 5th Gen Camaro SS LS LT General Discussions 63 05-07-2009 12:51 PM
And Another Car Crash... GTAHVIT Off-topic Discussions 73 01-12-2009 11:43 AM
