Old 05-05-2018, 06:20 PM   #1
yzinger
yzinger's Avatar
Drives: 2010 Camaro SS/RS - IOM - LS3
Dimple Headers on Car??
Hey guys, just throwing it out there.
Have any of you dimpled your header while it is installed on car?
My issue is passenger side frame rail. 2nd tube is quite tight (maybe 16th of an inch), so on most left hand turns it will touch, rattle or clunk etc..
I thought of moving motor over some but I am good on drivers side but not by very much and don't think it is a viable solution in my case.
I will unbolt and uninstall all if I really have to but to be honest, my C5 friends who say header install is easy must have some dainty hands because I beat my hands and arms up something awful and I have done many 2nd gen headers so I know tight!! (that being said anyone can installing their headers and should, it isn't "easy" but it is straightforward, simply frustrating and in my case, painful (i love it!) . Hence I hope someone in the community has done this while still on car.
Thanks for any ideas kids.
yzinger is offline   Reply With Quote
Old 05-05-2018, 07:14 PM   #2
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
What brand headers do you have?
I’ve had Kooks headers on and off my car and a friends car multiple times with no issues. They’re close to the steering shaft but are far from touching or rubbing anywhere else.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 05-05-2018, 08:37 PM   #3
saluki
Drives: 2017 Silverado
I have a set of 2" TSP's that are not dimpled. I didn't even remove the steering knuckle to install them.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 05-05-2018, 08:41 PM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
My Kooks headers go in and out with ease, not close to anything at all! Dimple if you have too, it wont hurt anything.
zz430camaro is offline   Reply With Quote
Old 05-05-2018, 08:52 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Yep, I've dimpled headers before to clear the steering shaft. There is a video out there of engine builders beating the crap out of a set of headers (on purpose) and the engine only lost 1hp. Don't be afraid to do it if necessary.
Found it:
Old 05-06-2018, 12:03 PM   #6
Joe Schmo
Joe Schmo's Avatar
Drives: 2010 SS/RS
I just installed 1 7/8" long tubes, and had the same problem. Especially on left turns. There was a little less than a mm of clearance to start with. No dimple necessary, really. Just put a pry bar on it, and bend a little. Only about 5mm clearance now on mine, so didn't need to pry/bend a lot. But after bending it just a little, the knocking, banging around, and rattling is gone.
Joe Schmo is offline   Reply With Quote
Old 05-06-2018, 02:38 PM   #7
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Your fine Zinger. Just make sure you give yourself enough dimple to clear. You dont to be doing it again.
rontammy0 is offline   Reply With Quote
Old 05-07-2018, 06:46 AM   #8
yzinger
yzinger's Avatar
Thanks all for the replies folks;
Regarding the poster who spoke to just using a pry bar, can you go into a bit more detail how you did it?
I thought of this exact thing but if a fella prys them from the bottom will it bend and put pressure where I want? I keep being scared it will put pressure on the header bolts only.
My issue sounds exactly like yours: soft motor mounts, motor not centered.
Old 05-07-2018, 06:57 AM   #9
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
What brand of headers did you buy? Depending on who made them they may send you a new set so that you don't have to dimple them.
Check out my build thread
Old 05-07-2018, 09:42 AM   #10
WheelMan69
WheelMan69's Avatar
Drives: 2015 SS/A6
Kinks in headers add more horsepower as per Engine masters!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2015 Camaro SS/A6--Roxy MOD'S
*Rear Muffler Delete
*VMAX Throttle Body
*Speed-Engineering Headers / No Cats
*Catted Magnaflow X-Pipe
*BMR Toe Rods
*BMR Xtreme Ant-Roll Kit
*BMR Trailing Arms
*CAI Cold Air Intake
*TUNED BY JAY @ KRAFTSWORKS EXCELL
WheelMan69 is offline   Reply With Quote
Old 05-07-2018, 10:20 AM   #11
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
Lol, free horsepower. All LT brands have this issue, you are going to need to adjust the engine via the mounts. I am going to hammer my LT headers now. I wonder if I have to get the car retuned. Lol.
JLGO is offline   Reply With Quote
Old 05-07-2018, 10:57 AM   #12
yzinger
yzinger's Avatar
hahaha, yeah lets all go out and beat the hell out of our headers and discuss the results
Old 05-07-2018, 11:03 AM   #13
xc_SS/RS
take them out of the car to dimple them lol good luck getting a good swing with a hammer while they're in the car
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-07-2018, 01:49 PM   #14
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Header dents FTW lol Thats my secret to great bolt on numbers
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
