Old 05-07-2018, 05:05 PM   #1
jerryboy50
Drives: 2015 SS Convertible
top down question?
I run top down without the tonneau cover most of the time on my 2015 SS because it's such a PIA to put on. I've noticed that when I get up to speed I can see the convertible top in my rear view mirror ruffling a bit in the wind...not much, but it's clearly visible movement. It's a little distracting. Is this normal?
Thanks!
jerryboy50 is offline   Reply With Quote
Old 05-07-2018, 08:56 PM   #2
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
Mine does it too
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 05-07-2018, 10:18 PM   #3
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
this is what causes the wear spots on your top fabric
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 05-07-2018, 11:23 PM   #4
jerryboy50
OK, what can be done about it? Run with the tonneau on all the time?
Old 05-08-2018, 06:30 AM   #5
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
The tonneau cover takes about 3 minutes to install on my 2011. Tuck it in around the sides, then clip the two middle clasps. I store it in the trunk when not in use.
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 05-08-2018, 10:45 AM   #6
sbubbaklein
yes, unless you want to replace the top when it wears through. Got mine replaced 1X already. Cover on all the time for me
Old 05-08-2018, 10:51 AM   #7
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
The only time my cover isn't on is if the wife is taking the car by herself. She doesn't want to deal with and won't put it on and off. It's not that often she takes it by herself anyway. I only have use of one hand, and it's no big deal for me to do. So I don't buy the excuse that it's a hassle, it's a choice.
Coleroad is offline   Reply With Quote
Old 05-08-2018, 04:34 PM   #8
jerryboy50
After looking at it closely, it looks like the wear mark across the top may be caused by the friction of the tonneau when it's on and snugged down. Mine also has the elastic loops on each side that attach to pegs to keep it tight.
Thoughts?
Old 05-08-2018, 06:50 PM   #9
sbubbaklein
[QUOTE=jerryboy50;10177643]After looking at it closely, it looks like the wear mark across the top may be caused by the friction of the tonneau when it's on and snugged down. Mine also has the elastic loops on each side that attach to pegs to keep it tight.
Thoughts?[/QUOTE
I also put a couple of towels between the folded top sections as I put the cover on. I am now very careful how I store my top since it was replaced.
Old 05-08-2018, 07:45 PM   #10
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
I drive around without the cover on a lot and have zero issues with wear spots. It does flap a little bit, but no biggie to me.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 05-09-2018, 05:36 AM   #11
KickerZ71
KickerZ71's Avatar
Drives: Camaro SS
I use the cover every time.
KickerZ71 is offline   Reply With Quote
Old 05-09-2018, 05:49 PM   #12
Tom And Cheryl
Tom And Cheryl's Avatar
Drives: 2013 SS Convertible, ThumperII
Ok were at about 70 cover, 30 percent not. mad dash home after work, sometimes I just go. When we are going somewhere than I normally put the cover on. We have the straps also.
Tom And Cheryl is offline   Reply With Quote
Old 05-09-2018, 10:18 PM   #13
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
Mine flaps too at 35 mph. I could care less. No wear marks.
18LTLoveIt is offline   Reply With Quote
Old 05-12-2018, 03:55 PM   #14
zandron263
zandron263's Avatar
Drives: 2011 2LT RS IOM Convertible
I rarely drive with the cover on. No issues with abnormal top wear after 7 years.
zandron263 is offline   Reply With Quote
