![]() Drives: 2011 SS Camaro 6.2L V8 Join Date: Dec 2012
2011 SS Camaro - Speakers go out
In advance, thanks for any help or feedback you can provide. If you have either of these issues, feel free to post below so maybe we can figure it out. I have a 2011 SS and I haven't done any audio upgrades or changes to the car at all.
Issue 1: When I close my center console, sometimes my speakers on the driver side go out. If I open and close the center console (basically slam it) they will come back on. Is there something in the center console I should try to check for as to why this is happening? Maybe a loose connection? Issue 2: I also have an issue with phone calls where my Bluetooth will disconnect my GMusicConnect (music) if I am on the phone for longer than a few minutes (on average 5-10 minutes). Is there an update I need to do for the Camaro and if so, how do I go about getting the update? I have had multiple iPhones to test this issue, and it seems to keep happening with each one. Any advice in the right directions for either of these issues would be greatly appreciated. Thanks guys! |
#2 | |
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2016
Nope. the GM pdim sucks. thats why they did away with it in 2013. built into radio.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
| Tags |
| 2011 camaro 2ss, bluetooth, disconnect, issue, speakers |
