Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 05-13-2018, 08:27 PM   #1
Zl1dad
Drives: 2013 zl1
Diff fluid change
I have a 2013 Zl1 that has 15k mi. It's seen 3 HPDE and lsfest last year. How often when tracking your car are you changing your gear oil.
Sent from my HTC 10 using Tapatalk
Zl1dad is offline   Reply With Quote
Old 05-13-2018, 09:03 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
I change yearly but, I track 6-8 road courses a year and it gets hot here. If yours has not been changed yet, I’d do it now. How often depends on how much you race. You have a diff cooler so you can run yours longer. If you race often like I try to do, yearly is a safety precaution. I change coolant yearly, trans 5k-10k miles (I’m a auto), oil until about 30% life left (I do have blackstone reports for diff, trans, and engine oil — which helps me decide when to change).
-Don
747 RWHP 794 RWTQ
Old 05-18-2018, 04:21 PM   #3
Zl1dad
Drives: 2013 zl1
-Don
Thanks Don. I looked it up in my manual and it recommends every 24hrs of track driving
Old 05-18-2018, 08:05 PM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I have less track days annually than Don, at around 3-4, but change annually. it's too easy not to...
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-19-2018, 09:45 AM   #5
Zl1dad
Drives: 2013 zl1
I have read the procedure and it's not just a drain and fill. It involves driving to warm, figure 8, drain, fill drive , figure 8s, drain drive fill.... Kinda seems like a pita. This may also be different for a Zl1.
Old 05-19-2018, 12:46 PM   #6
Olddudesrule
Resident nomad
Talking
You may be correct. The ZL1 may have a different rear end/clutch pack design.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 05-21-2018, 11:16 PM   #7
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
Any change of fluid is better than none... I would personally prefer to change the diff fluid when changing the engine oil for a few changes in a row to flush things out instead of doing that (excellent but time consuming) procedure.
TWOFORTYZ is offline   Reply With Quote
Old 05-23-2018, 03:15 PM   #8
z28lt1
Drives: 2014 ZL1
That's the procedure from a TSB where there is noise on cold turns from the diff. That TSB specifically states a regular maintenance change does not require any of that.
z28lt1 is offline   Reply With Quote
Old 05-24-2018, 04:56 PM   #9
Zl1dad
Drives: 2013 zl1
Thanks for clarifying. Mine makes noise on cold turns that's why I plan on doing procedure.
Old 05-24-2018, 05:08 PM   #10
camaroarm
Drives: Black and White
I have never consciously changed mine. I don't know if they do it at the service department when I take my car there for a regular checkup. Going to ask now.
camaroarm is offline   Reply With Quote
