Old 05-14-2018, 03:24 PM   #1
gtpvette
Drives: 2016 C7
LFX V6 - Remote CLutch Bleeder - Need a M8x1.25 fitting
Hey guys,,, doing an LFX swap and want to do a remote bleeder for the slave. The bleeder fitting is a 8Mx1.25. I cant seem to find a male to male fitting retaining the m8x1.25 bleeder on one side,,,, I'd take just about anything on the other, 2AN, 3AN etc.
Anyone ever find one of these Unicorns or have a line on where to get an assembled hose?????
gtpvette is offline   Reply With Quote
Old 05-15-2018, 09:21 PM   #2
Synner
Drives: cars
Google custom brake line and pick from a hundred companies that make them for a living. You just need to call, should be $75-100 for the full line with speed bleeder tops.
Old 05-16-2018, 09:31 AM   #3
gtpvette
Drives: 2016 C7
You'd think it be that easy. I've been looking for days,,, the best I've come up with is below. It's a two part bleeder out of Germany made for motorcycles. I'm thinking I can remove the top portion and put an adapter in with a crush washer. Maybe.
Anyone else have an idea???
Old 05-16-2018, 10:39 AM   #4
gtpvette
Drives: 2016 C7
Ordered the item above,,, ouch $38 plus the two below out of the UK. Hope full about the first one just screwing in,, don't know if it's long enough. Second one should screw into the bleeder above.
Old 05-29-2018, 12:22 PM   #5
gtpvette
Drives: 2016 C7
Well,,, the supplier for the motorcycle bleeder canceled my order, no stock. I did get the parts in from the UK. The top picture above is a bit misleading as the part doesn't look exactly the same. I''ll need a crush washer between it and the part it screws into. Hopefully it'll seal.
BTW in the pic below,, it's the top part. The bottom is the feed from the clutch master,, both at -3 AN.
Here is the bottom part:
https://www.summitracing.com/parts/ram-78310
