![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Whats the limit on this basic fuel system?
I currently have the usual stuff:
ZL1 pump Modified fpcm MSD BAP 90# Deatschwerks At 700whp, my inj DC is 48%. Can I push this setup to 850-900 on 93 octane? It will still be a centri style unit.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
![]() ![]() Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
I was making around 800 rwhp with an ECS kit, ADM twin pumps, FIC1000's and no BAP. However, I was running 100% meth + 93. I had plenty of pump and injector, but I was approaching the limits of safely running 93 + meth without detonation.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
#3 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
ZL1 w/BAP is max'd. What ^^^ said.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
Leave it Ted to spoil all the fun.
DSX Aux pump kit sounds like a good option at this point, unless i sell everything and start over. Just dropped good coin on a McLeod RXT 1200HD. It never ends...
#6 | |
I have an ADM twin pump and FPCM I'll sell you reasonably. I just pulled it to install the Fore Triple Setup.
#7 |
Your injectors obviously have some room but that pump is maxed. It's time for a Squash or a Fore Innovations pump. Give us a call when you're ready to order and we'll hook it up.
#8 |
![]() Drives: 2011 2SS/RS LS3 Join Date: Apr 2017
Is e85 available in your area?
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
#9 |
Yes, but i dont really need it, and it only makes the fuel demand worse.
#10 |
![]() Drives: 2014 SS 1LE Join Date: Apr 2014
lol wut
#11 |
If you’re upgrading to twin pumps, might as well go e85 too. Especially since you are FI. You can expect hp gains up to 75 at the wheels. That’s a lot!
#12 |
![]() ![]() Drives: 2014 SIM 2SS Join Date: Sep 2015
Is there a quantitative way to determine you need more fuel pump? Pressure drop?
#13 |
Yes e85 demands about 30 percent more fuel, but on that note i run a flex fuel set up and the performance between 91 and e85 is very significant because it allows you to run more boost and timing without kr
Cai intake and a few other mods😎
#14 |
The fuel system is the foundation on which everything else is built, too much is never enough.
Not the other way around but it is a trend I see every day, Build the car first then worry about the fuel system after you run out of money LOL Ted.
