Old 05-17-2018, 07:10 PM   #1
beak81champ
ILSQ
beak81champ's Avatar
Drives: '13 2SS/RS
Best spark plugs?
Once I’ve done LTH, CAI, muffler delete, and upgrade spark plug wires, are there better spark plugs than OEM that I should put on before I have the car tuned? I don’t have any other engine mods yet...
Way too many mods to list, and just getting started...
beak81champ is offline   Reply With Quote
Old 05-17-2018, 07:51 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Ngk
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-17-2018, 09:41 PM   #3
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
Put a fresh set of factory plugs in it. Wires are negotiable, I wouldn’t waste the money for them. I relocated my coils and had to make custom lengths is why I changed mine
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
KTMracing09 is offline   Reply With Quote
Old 05-17-2018, 11:14 PM   #4
beak81champ
ILSQ
Drives: '13 2SS/RS
A buddy of mine builds plug wires, so they won’t cost me anything...
Old 05-17-2018, 11:37 PM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
NGK or some fresh Delco plugs work great.
Juiced1 is offline   Reply With Quote
Old 05-18-2018, 12:20 AM   #6
InFiD3ViL
InFiD3ViL's Avatar
ACDelco 41-110 Professional Iridium Spark Plug for me.
Old 05-18-2018, 11:57 AM   #7
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
NGK , and no anti seize needed as they come with it on them from the factory.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 05-19-2018, 09:38 AM   #8
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Unfortunately, I go back to the days of leaded gas and having to change plugs every 3000 miles. I carried that practice over up to the 1990’s when it started becoming obvious that there was NOTHING wrong with spark plugs even up to 100,000 miles. Am just asking, why does anyone change their plugs on these cars?
Moto-Mojo is offline   Reply With Quote
Old 05-21-2018, 10:00 PM   #9
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
After a certain point they corrode and lose material, even with iridium and platinum plugs. I replaced the original plugs on my Crown Victoria at 90,000 and they looked acceptable but were visibly worn with rounded edges from erosion. I'm not planning on touching the plugs on the camaro until they're due based on mileage.
TWOFORTYZ is offline   Reply With Quote
Old 05-21-2018, 10:31 PM   #10
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
I did mine at 30,000 miles but the only reason I did was I was putting long tube headers on. They are really easy to do on these cars so if you want to go for it it won't hurt anything.
Talladega is offline   Reply With Quote
Old 05-29-2018, 01:33 AM   #11
rdanzel
Drives: 2010
AC Delco is really a good plug. There's no reason for me to try a different brand.
rdanzel is offline   Reply With Quote
Old 05-29-2018, 02:24 AM   #12
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
+1 ac delco
LsxDoctor is offline   Reply With Quote
Old 05-29-2018, 07:08 AM   #13
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
NGK TR5 for basic bolt ons stock replacement and NGK TR6 for cars making decent power. The TR 6 helps with knock retard. Wires are actually a sore subject for most. I use Firecore
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 05-29-2018, 07:19 AM   #14
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Oem.
rontammy0 is offline   Reply With Quote
