![]() Drives: 2010 Camaro SS/RS Join Date: Jul 2009
Licence plate lens
Can anyone tell me how the lens comes off to get at the bulbs. I see a black tab which I pulled but still won't come off.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Oct 2009
1) there is a clip at the left end of the housing - push to right and the housing should start to come down, you may have wiggle the clip to get the housing moving.
2) housing will pull out with the wires still attached to the socket, gently turn the socket to remove it from the housing. 3) Remove stock 194 bulb by pulling straight out. Replace with 194 LED, push in until tight. Re-connect socket with housing, turning socket until it locks in the housing 4) Re-seat housing in the bumper, clip goes on the left, until housing is flush & secure. 5) Repeat 1-4 with the other side. REMEMBER - there are two (2) bulbs/housing so you need to be sure you order two 194s from wherever you purchase. .
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
Thanks for the help.
| Front licence plate placement | Rocky918 | 5th Gen Camaro SS LS LT General Discussions | 61 | 11-17-2009 03:22 PM |
| licence plate bulbs | noisemker | Cosmetics and Lighting Modification Discussions | 1 | 08-23-2009 04:12 PM |
| FRONT LICENCE PLATE DISCUSSIONS | SQUALO | Canada | 28 | 08-06-2009 07:29 AM |
| front licence plate exception in Ontario? | Mike88 | Canada | 20 | 04-25-2009 11:23 AM |
| Alberta ~front licence plate holes~ | LS3SSRS | Canada | 5 | 01-30-2009 04:28 PM |
