9.96 NA SBE!
New setup for modified class at camarofest. Went to test the th400, new converter, and new engine setup.
Same intake as my old 417. New heads, new solid roller cam, and lighter than before. https://youtu.be/rtSMXb_AMpw Last edited by Rhino79; 05-19-2018 at 05:58 PM. |
Great run! Congrats
Nice! Congrats Ryan!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
![]() Drives: 2011 2SS RS Join Date: Dec 2015
Awesome work! If you don't mind me asking do you still have the stock springs and struts front and back? I noticed your car doesn't squat in the rear nearly as much as the older videos. Seems to hook much harder as well.
![]() Drives: 2014 2SS/RS Join Date: Feb 2015
Nice pass brother! I have 60ft envy!
Keep leading the way!
2014 2SS/RS TH400 Swap, CAI Cold Air Intake, SW LT's, PTB, GPI Intake Mod, Circle D Converter, DSS 9in conversion and Gears, GPI Cam and Heads..Tuned by "Ryan" GPI
#6 | |
'It's an experiment'
Nice Ryan!
Fixed the video link: -Don
747 RWHP 794 RWTQ
#7 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Wow, amazing run without blower! Great job!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
#8 |
Still stock. Little different alignment, Hendrix offset bushings, and u now have a th400. That y’all low gear makes for a smoother launch.
#9 |
Also currently on a Hoosier drag radial 275-60-15
#10 |
#11 |
Nice run, congrats. Nice to see some guys still doing it big N/A
#12 |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
haulin ass
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#14 |
Hendrix offsets?
Check this out: https://www.camaro5.com/forums/showp...postcount=1937 https://www.camaro5.com/forums/showp...postcount=1939 https://www.camaro5.com/forums/showp...postcount=1943 https://www.camaro5.com/forums/showp...postcount=2018 https://www.camaro5.com/forums/showp...postcount=2020 Some fun there! -Don
747 RWHP 794 RWTQ
