![]() ![]() Drives: 2011 Camaro 2LT/RS Black Join Date: Nov 2011
I've waited 7 years for a CAI and I finally got one (I'll explain why later). I am currently installing it in my LLT. Taking out the stock parts was easy but
two/three concerns came up with installing the CAI: 1) The CAI housing fit the contours of the wheel well...well .Is this normal or should I really try to force it in there? 2) The one bolt to hold it in doesn't appear that stable. The stock had what appears to be some type of stud sleeve for the nut. The CAI installation instructions doesn't mention to use it so I didn't. Also, the CAI housing seems to be loose close to the radiator. I can imagine it knocking around during normal driving. I saw some videos on youtube but they gloss over this portion of the installation. Videos and pics all show the installation w/ the screen on top, where it looks pretty good. Thoughts? |
Thoughts
Maybe you should do some cleaning before you bolt in some shiny new stuff.
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Are you sure you got the right CAI for your car; that doesn't look like it fits anywhere near correctly.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Looks like it's not pushed over far enough...to the driver's side.
Edit: On closer look, I guess it is. Otherwise the bolt holes wouldn't have lined up. Well that sucks. Looks like you may have the wrong intake, as mentioned by Welker. I would contact the Manufacturer. CAI's are too expensive to get a part that doesn't fit like a glove.
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Here’s mine:
#6 |
Hmmm..... it should fit the contour of the metal part of the fender and seal with the provided gasket. You might have to wiggle it around and make sure it's not contacting any cables or wiring. Mine sealed up against the metal portion of the front clip perfectly. Make sure the bottom of the CAI is pushed in and ligned up, if you're off on the bottom the rest will never align, it's a tight fit.
#7 |
#8 | |
Actually, your image looks pretty similar to mine. It doesn't contour to the wheel well all the way and it is pretty close to the radiator. Also, it looks like you do use the stud sleeve before the bolt. I'll try it out tomorrow morning and see what happens. Is the front part next to the radiator knocking against it or the AC line? |
#9 | |
Here's how the stud mounts up. ![]() This is the fit around the core support and A/C line. ![]() And a shameless plug for my freshly detailed engine bay. ![]()
#10 | |
Thanks to these pics and you guys help, I was able to install it! ![]() I still didn't clean out the engine bay due to time and weather but I'll usually attack it with Simple Green in late spring. Haven't driven it yet but I'll report back with my review. Thanks again! |
| Tags |
| cai, cai air intake, installation, issue |
