Old 05-27-2018, 06:55 PM   #1
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
'14 LS PDIM Question
So I've been trying to find more information of this but can't find a full answer.
In the 2014 2LS Camaro, is it possible to replace the stock AUX to a PDIM that enables bluetooth music streaming with the USB port? I've seen it been done in the earlier models but haven't seen anything for the 2014. I heard that the earlier model PDIM's won't work with the 2014 LS.
Bumbleboy92 is offline   Reply With Quote
Old 07-02-2018, 07:07 PM   #2
Bumbleboy92
Long hauler
So I did find the solution to this, for anyone with this problem in the future.
To enable the Bluetooth music playback in any 2014-2015 LS model we have to change the entire radio unit to one that supports it. So far the only place I was able to find that can do such a feat and have the proper instructions/harness to do so was Gen5DIY. Contacting them, they were able to let me know the procedure and required parts. But it was over $1,000 and I didn’t follow through with it. Just a $30 Bluetooth recover does the work which connects to the 3.5mm AUX port and a USB port (I use a 2x USB charger) for easiest playback without a cable.
Old 07-15-2018, 12:13 PM   #3
USCAMARO14
USCAMARO14's Avatar
Drives: 2LS 2014
Thumbs up
I did the conversion and it was worth it.
USCAMARO14 is offline   Reply With Quote
2014, bluetooth, music, pdim
