Old 05-28-2018, 07:32 PM   #1
mrbrans5
mrbrans5's Avatar
Drives: IOM Bahia Int. 2LT RS M6 SR BH
Anyone done a LT Clutch yet?
OK... here's a new one to me...
Picked up everything I need to replace my clutch on my 2010 3.6 LT Camaro the other day at the dealer. I told him I wanted everything, including new bolts. The dealer tells me ok but there is NO listing for a pilot bearing for this car?
Now, the dealer can't even suply me with one of those plastic alignment tools for your friction disc so im thinking, I'll have to get that, AND my pilot bearing somewhere else?
NOT!!
No one has a pilot bearing for this car!!
Can this really be?
How can this clutch have NO pilot bearing?
I've never heard of it!
If I'm in there, I want to change the pilot bearing as well.
My service manual shows a Pilot bearing and how to re and re it. It even shows the GM special tools they want you to use to do the job. It does not however say this procedure is specific to the SS or LT.
mrbrans5 is offline   Reply With Quote
Old 05-28-2018, 09:32 PM   #2
Witt51
Drives: Black 2ss
I don't think I would have them touch my car but not surprised.
I ordered mine from summit. 12 bucks for pilot bearing and 10 bucks for alignment tool. That was for an ls3 but can't see that it would be much different
Sent from my SM-N950U using Tapatalk
Witt51 is offline   Reply With Quote
Old 05-28-2018, 09:44 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
My Spec clutch came with a new pilot bearing and the alignment tool...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-29-2018, 01:29 PM   #4
gtpvette
Drives: 2016 C7
The V6 doesn't have a pilot bearing. Don't have a picture right now though. Got an LUK clutch assembly from Rock Auto does have the alignment tool (haven't installed it yet). Could measure it for you if you'd like. Flywheel bolt are one and done,,, pressure plate bolts can be reused.
https://www.rockauto.com/en/moreinfo...308745&jsn=448
Couple of LFX Miata swaps talking about it...
https://www.miataturbo.net/engine-pe...9/#post1312794
https://www.miataturbo.net/engine-pe...0/#post1312803
https://www.miataturbo.net/build-thr...0/#post1409726
gtpvette is offline   Reply With Quote
Old 05-29-2018, 07:38 PM   #5
mrbrans5
mrbrans5's Avatar
WOW... Very interesting reading.
I guess all I need to find is an alignment tool and I'm good to go.
Thanks for the information.
Old 05-29-2018, 10:13 PM   #6
gtpvette
Drives: 2016 C7
My pleasure,,,, post up your info as there isn't a lot for the V6 stuff.
Old 06-04-2018, 08:51 PM   #7
mrbrans5
mrbrans5's Avatar
Ok, with no pilot bearing, how do you align the friction disc when you bolt up the pressure plate?
Old 06-07-2018, 12:16 PM   #8
gtpvette
Drives: 2016 C7
My motor is back in the car at the moment,,, but it'll be back out again soon,, I'll take a picture then. That said the alignment tool looks like it'll slide into the back of the crank like it should. See pic below I got off ebay.
As a sidebar,, I was looking at the clutch that came with my transmission from the wrecking yard. LUK was stamped on it. Anyone know if that's what comes from the factory??
Old 06-13-2018, 05:15 AM   #9
mrbrans5
mrbrans5's Avatar
Here are some pictures of the replacement clutch I bought at my Chevy dealer.
Hope this helps.
Old 06-25-2018, 06:28 PM   #10
gtpvette
Drives: 2016 C7
Looks just like my LUK one from Rockauto.
