Old 06-02-2018, 12:44 PM   #1
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
ADM Performance LME LSX427 AGP Twin Turbo Build
My car goes under the knife again. I hope to document the build process over the next few weeks. This will be a big change from what I am use to. I have been running the Heartbeat Blower with a big shot of nitrous that peaked out around 1050Rwhp.
Big shout out to Andy at ADM Performance for all the work he is about to put into the car, and all the work he has already done to it. Thank you to Kevin at AGP Turbo for the assistance and upgrades on the Turbos. Thank you Bryan at LME for helping us put together one badass motor. And Thank you to RPM for the work on the Transmission and Torque Converter.
The Car: 2012 Camaro SS
The Trans: Stage 5 4L80 from RPM
LME LSX427 rated to 1500rwhp. Custom Cam
Brodix BR7 6 bolt heads
AGP Twin Turbo Kit Garrett Ball Bearings 65/65 with modifications
DragRace Intercooler
Doug Thorley Shorties
ZL1 Differential, ZL1 Axles, Upgraded Bushings BMR Xtreme Anti-Roll Bar
4L80 to ZL1 Diff 4inch Driveshaft
15in conversion ( LCAs, Trailing Arms, D/S Rear Rotors, Rear 4 piston calipers, 15x10 Welds, MT ET Street R)
Triple pump fuel system with 1700cc injectors
Large Capaicity Radiator with custom Fans and Shroud
Roll Bars
Transmission modifications by RPM with new Torque Converter
ALOT OF ADM MAGIC, SWEAT, BLOOD and TEARS.
Reserved for Updates:
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 06-02-2018, 02:58 PM   #2
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Originally Posted by Scuzz View Post
The new stuff:
LME LSX427 rated to 1500rwhp. Custom Cam, yummy internals.
Triple pump fuel system with 2000cc injectors
ZL1 Rear End
15 inch Conversion
Roll Bars
Congrats Scuzz!!!!!
I am doing almost the exact same build you are! Brian at LME started my 427LSx long block build 2 weeks ago.
Which Garret turbo's did you go with? I doing 65/65 BBs. AND Kevin is da man!
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 06-02-2018, 06:08 PM   #3
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
ADM is a top notched shop and OMG what a monster this sucker will be when done.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 06-02-2018, 07:56 PM   #4
AGP Turbo
Drives: All things Turbocharged
Should be a fun one.
I think people underestimate the blood, sweat and tears part. Cars at this level are intense.
AGP Turbo is offline   Reply With Quote
Old 06-02-2018, 09:20 PM   #5
Scuzz
Scuzz's Avatar
Originally Posted by ZX1truth View Post
Congrats Scuzz!!!!!
65/65
Yep im hoping the car is a monster for sure, BiggFoot.
Thats the great thing about ADM, they put their all into the cars, AGP Turbo.
Old 06-02-2018, 10:21 PM   #6
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Sounds like a monster in the works!!
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 06-03-2018, 03:15 PM   #7
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Big $$$$$ build. Congrats on having the resources to do it. 8's or high 7's hopefully.
Unavowed is offline   Reply With Quote
Old 06-04-2018, 12:04 AM   #8
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
65/65
Go BIG or go home!!!! We are going to have fun!!!!
Old 06-05-2018, 11:13 PM   #9
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
In for the build! Congrats! I too am doing a build but with a 416ci and twin T4 6266’s. I’ll be following your thread!
RealQuick is offline   Reply With Quote
Old 06-07-2018, 02:21 PM   #10
Scuzz
Scuzz's Avatar
It starts by stripping her clean so that she can be built from the ground up. Its a understatement to say ADM leaves no stone unturned.
Old 06-07-2018, 10:12 PM   #11
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Nice!!!
Old 06-19-2018, 05:50 PM   #12
Scuzz
Scuzz's Avatar
Rear Brakes and Rear Wheels
Old 06-19-2018, 05:51 PM   #13
Scuzz
Scuzz's Avatar
Rear End
Old 06-19-2018, 10:57 PM   #14
Unavowed
Unavowed's Avatar
I'll never understand why people put red calipers on yellow cars or vice versa. Send them out for powdercoat while the car is under the knife.
