Old 06-03-2018, 06:54 PM   #1
fleebag
fleebag's Avatar
Drives: Moneypit
Alky nozzle placement vs IAT sensor
Thinking of adding alky but if my IAT’s are read off the the mad
Then I would have to spray prior?
I do not see an IAT on my intake as I swapped from the Maggie to twins.
If you put it near the TBody I would assume it wouldnt work as the IAT readings are before the nozzles.
Thanks
fleebag is offline   Reply With Quote
Old 06-03-2018, 06:59 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You need to breakout out IAT sensor from the MAF and move it closer to or behind the TB. Then place your meth nozzle(s) after the MAF but before the IAT sensor.
Search for IAT breakout harness.
Old 06-03-2018, 07:10 PM   #3
fleebag
fleebag's Avatar
Drives: Moneypit
Kinda like I did my GN I guess, as I moved it
to the rear of TB snout.
Next ?, you know which wires offhand? Lol
Thanks
Old 06-03-2018, 11:13 PM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Thanks
Easiest thing to do is spend ~$30 for the harness and then whatever the IAT sensor costs.
From 2010-2011 service manual:
Old 06-04-2018, 06:50 AM   #5
fleebag
fleebag's Avatar
Drives: Moneypit
Thanks man!
