![]() Drives: IOM 2SS/RS M6 Join Date: Oct 2009
Kooks header gaskets
To all with Kooks headers.... Did you use the supplied gaskets or something else? When I put Kooks on my 09 Challenger, I was warned to NOT use the supplied Kooks gaskets...
Drives: 1999 Trans Am Join Date: Jul 2009
We uae new stock GM gaskets for 98-02 Camaro's.
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
Yep, I've had excellent results from the GM gaskets on my 4th gen.
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
kooks supplied carbon gaskets working great here, same gaskets i have used on several of my vehicles and never had an issue with them
![]() Drives: Black 2SS Join Date: Oct 2009
I'm using the GM gaskets without any problems.
#6 |
#7 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
No...DO NOT use the Kooks gasket. Your stock gasket is a multi layer steel gasket that is reusable. I have reused the one on my GTO (same part) through 6 header installs (we have done a lot of tests). Throwing a way a fine multi layer steel gasket and replacing it with a carbon one is not good in any application. One top of not being as durable, the carbon one will leave crap all over your head that needs to be cleaned off if you ever replace your headers again. The metal one will not.
Everytime a customer calls us complainling about a leak, it always turns out they used the Kooks gasket. I have talked to Kooks about the issue, and what it boils down to is, if they include GM gaskets, the headers would cost $20 more. They think it's better to save the $20 because the stock gasket is fine to reues many times. |
#8 |
Frog
Do you have to put anything on the gaskets or just leave them plain as is
I'm not speeding....
.... I'm qualifying ![]() IYAAYAS |
#9 |
![]() ![]() Drives: 2010 LSX Shootout World AM Finalist Join Date: Sep 2009
throw out the kooks gaskets use your stock gaskets
#10 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
#11 |
NOICE!!! ™
Use the GM gaskets
#12 |
480 HP 2010 2SS
I reused my stock gaskets with no issues.
Without data you are just another person with an opinion.
1100 :10/15/08 3000:3/2609 3300:4/18/09 3400 (broadcast)April 25, 2009 3800 (produced):May 4, 2009 #7470 ![]() 4200 (Shipped): June 1, 2009 5000 (At Dealer) June 9,2009 374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg. |
#13 |
![]() Drives: 2010 Camaro 2SS/RS - IOM/IOM Join Date: Mar 2009
Reused my stock gaskets as well.
L99 with 2.8 LC Kenne Bell, Kooks 1 7/8 headers, Corsa Catback, R2C CAI, 491 RWHP / 500 RWTQ ---- 2010 MY #7539
#14 | |
![]() Drives: 2010 2SS/RS L99 Join Date: Nov 2009
Great info but, it would have been nice to have known this before I installed the Kooks.
| Kooks Header System In Stock!!! | ProchargedSS | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 22 | 05-21-2010 10:32 AM |
| Exhaust gaskets for Shorty Header install | HeavyD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 11-20-2009 03:37 PM |
| Kooks header specials for GA only, $1550 installed | JICPerformance | USA - Southeast | 0 | 08-25-2009 11:48 PM |
| KooKs Header ??????? | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 07-03-2009 11:13 PM |
