![]() Drives: 2015 V6 LT (RS Package) Auto Join Date: Jun 2018
I have recently purchased a second hand 2015 V6 (Auto) LT Camaro (with RS package), done 42,000 miles, it is still under warranty, but I feel that the car is underpowered for a 323 HP car, and that the acceleration/punch is not hard enough, so I measured the 0-60 time and found it to be almost 9 seconds!!, is that by any means normal?? My other observations are: a bit high average fuel consumption (16.80 MPG), a sudden change of engine tone after 3-4k RPM when stepping hard on the gas (is that by design?), and the passenger side hissing sound on hard acceleration.....any suggestions, please??
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Take it to the shop and have looked over. It should perform better than that.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
![]() Drives: 2012 Camaro SS 45th Anniversary LS3 Join Date: Nov 2016
Auto v6 0-60 should be around 6 seconds
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
If you're still under warranty, just take it to the dealership.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
With that 0-60 time you would be door handle to door handle with a Prius...
#6 |
Drives: Camaro V6 Join Date: Oct 2016
Passenger side hissing? Sounds like a major vacuum or exhaust leak.
#7 |
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
Find a way to data log it
#8 |
Status Update:
The car pulls much better now after driving it like a maniac for a couple of months, so either the Italian tune-up is a thing, or maybe the transmission adapted to my style of driving better, and the downshifts became quicker. for the passenger side sound...it is more of an "air mixed with sand sound" that happens when the RPM goes high...so maybe it is just some filter or duct that needs cleaning. |
#9 |
![]() Drives: 2010 2LT Victory Red Join Date: Sep 2011
Sounds like suction pressure loss due to carbon / recycle valve issue/ Should throw a code !
Previous Vehicles
1970 Impala 2D 350/300 1972 Buick GS 350 1967 Pontiac Firebird 326 1969 Chevelle SS 396/375 I really miss this one 1966 Chevelle SS 396/350 1978 Plymouth Fury 440 1982 VW Scirocco ( Got married ) 1987 VW Scirocco 1992 Ford Taurus V6 1996 Dodge Intrepid 2002 Dodge Intrepid 2002 Mercedes ML500 2010 Camaro 2LT |
#10 | |
| Tags |
| underpowered, v6 lt |
