Old 06-10-2018, 02:23 PM   #1
PhatStackSS
PhaSSt
PhatStackSS's Avatar
Drives: 2011 Camaro SS
Night Fury Cam in '11 SS
I recently just put a Night Fury Cam in my car. (I'm a newbie when it comes to engine work; luckily my brother & father are mechanics and help). My uncle works on race cars & suggested I put different springs and rods in since the Night Fury Cam is bigger than stock. I have been using all stock parts but now thinking about it, should I take his advice.. I mean I am going to but what rods & springs should I get? BTR Chromoly rods have been sitting in my head for a long time, as well as the springs. I just haven't fell through with it yet. Also fuel injectors.. should I get new ones? Or is it better to call whoever from Lethal Racing and get their thought/facts of what I need to get for the cam? I also was thinking of getting new lifters, but I'm assuming the lifters should be fine..? My car has about 65k miles, the lifters look new still. Thoughts on my situation please and thank you!
2011 Camaro SS | Cat-Back Borla ATAK | Roto-Fab CAI | Night Fury Cam | Kooks 1 7/8 x 3" Headers
PhatStackSS is offline   Reply With Quote
Old 06-10-2018, 02:48 PM   #2
saluki
Drives: 2017 Silverado
can you list what you have on the car? also if you are still using the stock blue valve springs park the car and don't start it until you change them
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 06-10-2018, 03:59 PM   #3
PhatStackSS
PhaSSt
I am currently putting the Night Fury cam in & Kooks headers. I have a Borla Cat-Back exhaust & Roto-Fab CAI I'll be putting back on it. But everything else is completely stock.
Old 06-10-2018, 04:03 PM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
You must get new valve springs and pushrods for the cam. Texas Speed can get you the correct ones. Its not a bad idea to get new quality lifters but you need to take of the heads to replace the lifters. Dont buy cams from Brian Tooley, they have problems with them. Go to Texas Speed, they can get you a cam or grind you a night fury.
zz430camaro is offline   Reply With Quote
Old 06-10-2018, 05:02 PM   #5
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
Thats interesting to hear. I've never heard of any problems with them.
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 06-10-2018, 05:04 PM   #6
PFL
PFL's Avatar
Drives: Camaro SS
Did you come to that conclusion alone? BTR racing has the best cam.
PFL is offline   Reply With Quote
Old 06-10-2018, 05:23 PM   #7
zz430camaro
Drives: 2015 1LE
Let me re-phrase that, dont buy cams from them that are ground by Comp Cams, there is plenty of data to support this. Just ask Bo White, he pulled a BTR stage 3 that was coming apart with pics to prove it. Here is the pic from when he pulled out the cam, would you put one in after seeing that? Its happened to many of them if you search around, sad but true.
Name:  cam lobe fail.jpg
Old 06-10-2018, 05:45 PM   #8
PhatStackSS
PhaSSt
Well I already have the Night Fury cam in. I'll be calling tomorrow morning to see what springs & rods are recommended for the cam. & I have heard nothing but good about BT. You're the first I have heard say something negative. I mean everyone has their opinion about things but you'll never know until you test it out yourself. Live and learn
Old 06-10-2018, 06:45 PM   #9
saluki
Don't by springs from texas speed they have problems with them. ask all the guys that used there .650's. ask LS1TECH
no matter that these incidences happened a while ago.
Old 06-10-2018, 09:22 PM   #10
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
LOL!! This thread is full of #FAIL!
BTR Cams and valve springs are fine. Comp Cams are fine. Plenty of folks are running them with no issues.
Yes, comp cams did have a run of bad camshafts, but that was a very small percentage of their overall heavy production.
OP: Yes, you will most def need hardened Pushrods and valvesprings, whether they are BTR or another company. Just make sure you get the correct length.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 06-10-2018, 09:40 PM   #11
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Good luck talking to lethal racing. They went out of business YEARS ago.
When Lethal went out, BTR picked up the night fury. So BTR would be the one to call.
Old 06-11-2018, 12:48 AM   #12
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
If you dont know you need better than stock springs with and aftermarket cam, dont do it yourself. You clearly need to read a lot more on the subject. I dont suggest you to put better springs and pushrods, I command you to do it.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 06-11-2018, 12:34 PM   #13
jc615
jc615's Avatar
Drives: Camaro and Sierra
He doesn't have to put them in...he just won't have a running car for long lol.
Also, I wouldn't worry about BTR cams. If it was that bad they wouldn't be selling them. Last time we heard about the bad batch of cams was a while ago
jc615 is offline   Reply With Quote
Old 06-14-2018, 12:59 PM   #14
Morgan.13
Drives: 2011 camaro 1ss
I just did my night fury cam install, I used the BTR platinum double springs with the titanium retainers, and 7.400 hardened pushrods(you should measure to make absolutely sure). You might want to consider a melling oil pump, and Katech c5-r timing chain. I personally replaced all my litters with new ones when I did mine(40,000 miles on them) for peace of mind. If you’re going to go through all the work might as well do it the right way
Morgan.13 is offline   Reply With Quote
camaro, night fury, opinions, push rods, valve springs
