Old 06-11-2018, 05:41 PM   #1
SSherrard
Drives: 2011 Camaro SS, automatic, black
Exclamation Camaro SS brake pad choice? HELP!
Can someone tell me what pads to use that won’t make an extremely annoying brake squeal? I have a 2011 Camaro SS and I’ve tried numerous pads, different brands, different compounds and they still squeal louder then a bus. Right now I’m on R1 Concepts street pads. I daily my car and I’m looking to sell it soon but I can’t sell it with the brakes sounding the way they do. I’ve also tried greasing every component of the brakes where metal touches. I didn’t have this issue when I bought the car used 3 years ago, but I have no idea what pads were on the car. If someone could give me their input on what combination of pads and rotors they use I would greatly appreciate it! I’ve also heard many times “performance brake pads and Brembos squek so deal with it” but like I said I didn’t have this issue before and I want to go back to a silent brake pad.
SSherrard is offline   Reply With Quote
Old 06-11-2018, 06:07 PM   #2
BlackCam14
BlackCam14's Avatar
Drives: 2014 Camaro RS
I used the brake performance ceramic brakes for my V6 upgrade. They only make noise once in a while when their cold, first stop etc. but usually quiet
BlackCam14 is offline   Reply With Quote
Old 06-11-2018, 06:43 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Did you perform the bed on procedure on the pads?
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-11-2018, 07:55 PM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
I would get the rotors turned and put on the factory GM pads.
AC Delco 171-1112 Pads
AC Delco 177-1050 Rotors
zz430camaro is offline   Reply With Quote
Old 06-12-2018, 06:03 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2020 S560, 2013 SS
The brembos like to be used aggressively. The harder I brake, the less noise mine make. This is common.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 06-12-2018, 08:48 AM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
+1...lol I have been usin Advance Auto (Wagner?) brand pads and rotors...inexpensive and per above if they start to get noisy I just take it up to speed and brake aggressively short of anti lock...prob solved until next time...
heck when I'm drag racin by the 3rd or 4th run they are squealin like pigs...afterwards on the ride home....silence....
peace
btw - has the brake fluid been bled? pedal should be very firm(mine is)...since I am M6 changin the fluid also changes the clutch fluid...and have bled my brakes 2x since ownin it (3yr now)..
Old 06-12-2018, 11:24 PM   #7
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Stock Brembo pads are awesome track or street and don't squeak in my experience.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 06-17-2018, 10:25 AM   #8
SSherrard
Thank you for this I’ll give it a shot with these. Someone also mentioned to order all new caliper bolts bc they are a one time use type of deal so I’m gonna do that too. Hopefully this will work
Old 06-17-2018, 10:27 AM   #9
SSherrard
Yeah pretty much same situation here but I can’t pull up to every intersection and brake check the people behind me every time 😂
Old 06-18-2018, 08:07 AM   #10
DCC
DCC's Avatar
Drives: Rally Yellow 2012 2SS
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER ...Whats the difference in these Pads
DCC is offline   Reply With Quote
Old 06-20-2018, 08:50 AM   #11
DCC
DCC's Avatar
peace
Do you know the part number on the Pads ?
brake pads, brakes, brembo, pads, rotors
