06-16-2018, 01:01 PM | #1 |
Drives: 2010 2SS 55k Join Date: Aug 2015
X pipe or SLP bullets???
Looking to quiet my exhaust a bit. I’m running LTs to str8 pipes, res delete and no mufflers. I want to add a x pipe or slp bullet mufflers but still want to sound mean. I think adding both would really kill my sound. Which one should I go with?
'10 2SS: SLP TVS2300, 3.4 JRE Pulley, ARH 1 7/8 LTs, Loudmouth I w/ res del muffler del & mf xpipe, SLP BlackWing CAI, NW102, Zl1 Fuel Pump, Alky Meth Single Nozzle, FIC 1000s, 3200 circle D, making around 500whp ( Frankenstein heads&cam coming soon... )
06-16-2018, 01:10 PM | #2 |
I would put the X pipe on regardless, but I wouldn't expect much sound reduction with it.
Kill two birds with one stone and go with Magnaflow resonated X pipe?
06-16-2018, 05:11 PM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
X pipe
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
06-16-2018, 07:07 PM | #4 |
Drives: 2010 Cyber Gray LS3 SS/RS Join Date: Jul 2017
I added 9” bullets in place of my catless connection pipes. So my exhaust is now, LT’s, 9” bullets, stock resonators, and cherry bomb extremes in the axle back. The bullets knocked down a lot of the harshness. It’s still loud, and barks when in the throttle. Drones a little around 15-1800 on the highway.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
06-16-2018, 11:38 PM | #5 |
1SS Victory Red Manual
Drives: 2010 1SS 6 Speed Manual Join Date: Apr 2009
Magnaflow Resonated X Pipe
1st Camaro - 77 Type LT Rally Sport, 3 Speed Manual, Inline 6 2nd - 94 Z28, 6 Speed Manual LT1 V8 3rd - 2010 1LT, 6 Speed Manual LLT V6 4th - 2010 1SS, 6 Speed Manual LS3 V8, RX Catch Can, Holley iNTECH CAI, Flowmaster Force II Exhaust |
06-17-2018, 02:11 AM | #6 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
But then I found that this modification differs only with the sound (X-pipe vs. H-pipe). And when I heard the Camaro SS with an X-pipe .... exotic car. No thank you. I have an American musce car from old school. So just the H-pipe only. On my 1978 Type LT I also have an X-pipe, but there will be an H-pipe. X-pipe does not sound good (for me) |
06-17-2018, 07:56 AM | #7 | |
https://youtu.be/C-JbgFuuDts
06-17-2018, 08:14 AM | #8 |
old school chevy rodder
Actually I would recommend Monza tips a resonator tip.... Used to use them on my old straight pipe muscle cars. PACESETTER....stuff. You have FI so your not going to get highflows to quiet the rasp. One nice note, old school Monza tips used to tweet for me, a mild chirping with the lope of the cam at idle kind of always reminded me of spurs jingling. And since they are basically a little cherry bomb type muffler at least you could claim some sound reduction as a muffler if pulled over.....
https://www.bing.com/images/search?q...aust&FORM=IGRE and there are some of course utubes of cars with them on if your old school like me you've used them and others over the years.
06-17-2018, 08:44 AM | #9 | |
It's hard to describe what I mean. My 78 Camaro STROKER 383 with x-pipe sounds smoothly like an one eight-cylinder. But my 2010 SS with H-pipe it sounds like two four-cylinder. And that's what I like. Do you know what I mean ..? Otherwise you have a very nice Camaro |
06-17-2018, 09:47 AM | #10 |
Drives: 2018 1SS M6 Join Date: Nov 2014
This is exactly what you want. I had a '96 LT4 Corvette no cats, no mufflers and the resonated x-pipe, cammed as well, and this sound was perfect. Still very aggressive, screamed at WOT, yet I could daily drive it w/out going nuts.
06-17-2018, 10:25 AM | #11 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
I agree with the resonated x pipe. When I put it on my car it really cut the volume down. But it did get rid of the high pitched rasp and gave the car a nice low growl.
