![]() Drives: Moneypit Join Date: Nov 2013
Hard start since swap to turbo
Ever since swapping to turbo it has trouble starting once warm.
It’s not a starter issue as it turns over great. Played around with cranking ve but no luck. Read an older post from other site possible iat heating up?maybe relocate? Cold start is fine only once to operating temp does this happen. I’ve tried two different tuners tunes with same result. Just got stranded at grocery store lol went back up there 40min later and started fine. Thanks in advance Last edited by fleebag; 06-16-2018 at 03:10 PM. |
#2 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I am just thinking out loud here, it could be vapor lock, the fuel boils in the fuel rails because there in no pressure engine off if you have a return system. You can add a check valve to hold some pressure and reduce the possibility of vapor lock.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
Thanks man, no we never finished what we started lol.
I did play with the cranking fuel 150* up and has gotten better. Even last night I got back in the car and it showed 210* and first turn of key it only turned over. Second turn it fired up As for fueling, I'm return oem style. Thanks again Ted |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I've had batteries that test good with a Volt meter, but when the engine gets hot, it wouldn't turn the motor over. Check it with a volt meter while cranking hot, and you may find a huge drop in voltage. If so, replace. If you mean it is turning over easy, but not firing up, then try adding some airflow to this table.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
#5 | |
Thanks, appreciate it. |
