Old 06-19-2018, 10:14 AM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
416 Stroker stock pump/injectors
Does anyone know if you can run a 416 stroker with the stock injectors AND stock fuel pump? This is a nitrous car and I have a dedicated fuel cell/pump for that. Should be making between 500-520rwhp on stock compression.
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 06-19-2018, 12:35 PM   #2
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I’ve got a 418 and ran out of injector. Went with 52lb. I don’t know about the SS pump, mine came with the ZL1 pump.
h018871 is offline   Reply With Quote
Old 06-19-2018, 02:23 PM   #3
booneSS13
booneSS13's Avatar
How much power did you make?
Sent from my VS988 using Tapatalk
Romans 5:8
Old 06-19-2018, 04:56 PM   #4
SSAvery
Avery@Texas-Speed.com
Drives: 2010 2SS/RS
Stock injectors are around 42 pounds at the rail and with 600ish HP at the flywheel they will be running roughly 80% duty cycle. My SS makes 495 wheel and there seems to be plenty of pump and injector. I think you will be fine with the SS pump and injectors, but they may be working kind of hard.
A
2010 2SS/RS - Texas Speed 1 7/8 Headers + 3" Off-Road X & NPP Axle-Back. Roto-Fab. Texas Speed Stage 3.2 Cam. SLP UDP. Aikman Performance Tuned 495 RWHP / 445 RWTQ on a DynoPack.
SSAvery is offline   Reply With Quote
Old 06-19-2018, 06:51 PM   #5
Bo White
Bo White's Avatar
If running pump gas just buy LSA injectors and a ZL1 pump
Old 06-19-2018, 06:54 PM   #6
booneSS13
booneSS13's Avatar
Thought you couldn't run LSA injectors because of the different spray pattern? I'm almost thinking about running a boost a pump and stock injectors. Seems like the C6 Z06 guys are making up 550rwhp on the stock injectors.
Romans 5:8
Old 06-19-2018, 06:58 PM   #7
booneSS13
booneSS13's Avatar
A
Great explanation. 600 at the flywheel is appropriately 510 to the wheels kind of looks like where I'll be at
Romans 5:8
Old 06-20-2018, 12:10 AM   #8
Bo White
Bo White's Avatar
Including myself I know of plenty of people running LSA injectors on an LS3/L99 manifold.
Old 06-20-2018, 10:09 AM   #9
SSAvery
Drives: 2010 2SS/RS
This is assuming you are going to be on pump gas. If running E85, you will definitely need to address the fuel system. Sounds like a fun build!
-Avery
Old 06-20-2018, 10:15 AM   #10
booneSS13
booneSS13's Avatar
Wow that's interesting. I think you may be right. I looked more into it and saw other people using them NA as well. It's amazing on how much misinformation gets spread around.
Romans 5:8
Old 06-20-2018, 10:17 AM   #11
booneSS13
booneSS13's Avatar
-Avery
Yes I'll be running pump gas. Definitely should be, I'm excited to get the motor back in the car.
Romans 5:8
Old 06-20-2018, 10:27 AM   #12
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I don't have that engine yet.
However I am going to install ID1050x injectors and going with a dual fuel pump for the future 416 stroker that I will obtain.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 06-20-2018, 10:54 AM   #13
jc615
jc615's Avatar
Drives: Camaro and Sierra
I ran LSA injectors NA on a heads/cam car just fine. I also installed the zl1 pump since I knew e85 was in my Future.
jc615 is offline   Reply With Quote
Old 06-20-2018, 01:09 PM   #14
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Same.....and on my 429ci stroker; LSA injectors and stock fuel pump.
540+ hp to the wheels.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
duty, fuel delivery, gas, stroker engine
